I have installed 10.2.2 FP6 64 bit on my computer. I am able to connect to my tm1 servers (ex. planning sample) via architect and perspectives but the tm1 servers are not listed down for tm1web and tm1 application login.
http://localhost:9510/pmpsvc/initialize.jsp
http://localhost:9510/tm1web
Tried the steps mentioned in below link but still the same.
http://www-01.ibm.com/support/docview.w ... wg21978399
Please help
TM1 servers not listed in tm1web & pmpsvc
- Version: 9.5.1, 9.5.2, 10.2.2
- Excel Version: 2007 2010
- gtonkin
Re: TM1 servers not listed in tm1web & pmpsvc
Have you been through all the steps for the SSL update as listed here? Especially steps relating to java/tomcat environment.
- Excel Version: 2013
Do you get anything when you go to http://localhost:9510/pmpsvc/ ???
If so, have you added the admin host and server to the TM1 Application Config?
Go to: http://localhost:9510/pmpsvc/
Click the tools in the upper right corner. (Administer TM1 Applications)
Then click add on under "server names" and fill in your info.
Following the steps for manual update for SSL certificate expiry, now i am able to see the server list via tm1web.
When i try to launch performance modeler to connect to planning sample or any other sample instance ( downloaded and installed performance modeler client from application home page http://localhost:9510/pmpsvc), i am getting the error message "Unable to connect to Planning Service".
Tried the below but did not fix it.
http://www-01.ibm.com/support/docview.w ... wg21648689
copied the NewSSLCert files to ssl path for performance modeler C:\users\user name\AppData\...
Please help
Please help
- gtonkin
Have you tried setting UseSSL=T in your tm1s.cfg?
Yes,tried UseSSL=T but did not solve the issue
PM works finally. My mistake, i now copied the newSSLs into ssl folders under all bins and plugins folder. Now PM connect to all sample servers.
Thanks for the help.
"<perfmodeler folder>\bins\bin_10.xxxx\tm1\bin\ssl"
"<perfmodeler folder>\bins\bin_10.xxxx\tm1\bin\tm1api101\ssl"
"<perfmodeler folder>\bins\bin_10.xxxx\tm1\bin\tm1api102\ssl"
"<perfmodeler folder>\plugins\com.cognos.pmta.tm1.distributed.bin.win32.x86_64_10.xxxx\extract_bin\tm1\bin\ssl"
"<perfmodeler folder>\plugins\com.cognos.pmta.tm1.distributed.bin.win32.x86_64_10.xxxx\extract_bin\tm1\bin\tm1api101\ssl"
"<perfmodeler folder>\plugins\com.cognos.pmta.tm1.distributed.bin.win32.x86_64_10.xxxx\extract_bin\tm1\bin\tm1api102\ssl"
