TM1 servers not listed in tm1web & pmpsvc
jagan_Palanisamy
Version: 9.5.1, 9.5.2, 10.2.2
Excel Version: 2007 2010
Post by jagan_Palanisamy »
I have installed 10.2.2 FP6 64 bit on my computer. I am able to connect to my tm1 servers (ex. planning sample) via architect and perspectives but the tm1 servers are not listed down for tm1web and tm1 application login.
http://localhost:9510/pmpsvc/initialize.jsp
http://localhost:9510/tm1web
Tried the steps mentioned in below link but still the same.
http://www-01.ibm.com/support/docview.w ... wg21978399
Please help
Re: TM1 servers not listed in tm1web & pmpsvc
Have you been through all the steps for the SSL update as listed here? Especially steps relating to java/tomcat environment.
BR, George.
Bakkone
Post by Bakkone »
Do you get anything when you go to http://localhost:9510/pmpsvc/ ???
If so, have you added the admin host and server to the TM1 Application Config?
Go to: http://localhost:9510/pmpsvc/
Click the tools in the upper right corner. (Administer TM1 Applications)
Then click add on under "server names" and fill in your info.
jagan_Palanisamy
Following the steps for manual update for SSL certificate expiry, now i am able to see the server list via tm1web.
When i try to launch performance modeler to connect to planning sample or any other sample instance ( downloaded and installed performance modeler client from application home page http://localhost:9510/pmpsvc), i am getting the error message "Unable to connect to Planning Service".
Tried the below but did not fix it.
http://www-01.ibm.com/support/docview.w ... wg21648689
copied the NewSSLCert files to ssl path for performance modeler C:\users\user name\AppData\...
Please help
Have you tried setting UseSSL=T in your tm1s.cfg?
BR, George.
jagan_Palanisamy
Yes,tried UseSSL=T but did not solve the issue
jagan_Palanisamy
PM works finally. My mistake, i now copied the newSSLs into ssl folders under all bins and plugins folder. Now PM connect to all sample servers.
Thanks for the help.
"<perfmodeler folder>\bins\bin_10.xxxx\tm1\bin\ssl"
"<perfmodeler folder>\bins\bin_10.xxxx\tm1\bin\tm1api101\ssl"
"<perfmodeler folder>\bins\bin_10.xxxx\tm1\bin\tm1api102\ssl"
"<perfmodeler folder>\plugins\com.cognos.pmta.tm1.distributed.bin.win32.x86_64_10.xxxx\extract_bin\tm1\bin\ssl"
"<perfmodeler folder>\plugins\com.cognos.pmta.tm1.distributed.bin.win32.x86_64_10.xxxx\extract_bin\tm1\bin\tm1api101\ssl"
"<perfmodeler folder>\plugins\com.cognos.pmta.tm1.distributed.bin.win32.x86_64_10.xxxx\extract_bin\tm1\bin\tm1api102\ssl"
