Hey Guyzz, need your help and guidance
I have updated my TM1 server with the updated certificates.
Now the prob is I am not able to login to any of the TM1 server through ARCHITECT, but after updating the Certificate Authority path in perspective and TM1p.ini I can login through perspective.
Need Help
SSL Certificate Update : Unable to login to TM1 Architect although Perspective is working finr=e
- jim wood
- Version: PA 2.0.7
Re: SSL Certificate Update : Unable to login to TM1 Architect although Perspective is working finr=e
There is already a large thread about the SSL change. Have you gone through that at all?
dharav
- Version: 10.2
1) Have you installed both Architect and Perspective at same location?SBK88 wrote:Hey Guyzz, need your help and guidance
Need Help
If no. then you must have to update the licensing certificate at both places. One might be on server and another might be on your local machine.
I raised the above question as the licensing update steps for both Architect and Perspective are same.
2) If you are accessing both from your local machine then
Copy those 7 licensing files, go to prog or prog86>ibm>cognos>tm1>bin>ssl>paste all files
Right Click on uninstall file to run as an administrator
Now, Right Click on Import license file to run as an administrator
Now you should be good with your Architect and Perspective Access.
SBK88
- Version: 9.5.2
- Excel Version: 2013
Yes it worked for me bro.... Thanks
