The SSL break and TM1Top
Posted: Mon Nov 07, 2016 9:20 pm
by PavoGa
Has anyone had trouble getting TM1Top to work with the new IBM SSL certificates? I have been unable to get it to work. No problem with Ops Console.
Re: The SSL break and TM1Top
Posted: Thu Nov 10, 2016 1:52 pm
by dsproffitt
Please post
1) What do you see (error messages)
2) What have to done to investigate the issue
Then we can make a start.
Posted: Thu Nov 10, 2016 3:49 pm
by PavoGa
"Could not connect to server "tm1instance" on admin host "servername"
Looks like our problems are all over the place. Got VMs connecting with no problem, Perspectives connects with no problem on a client laptop, but on the same client, Architect will display the instances and not allow a login (click on the instance, get a spinning circle for a few seconds, then nothing).
We're getting all the other problems straightened out and maybe that will correct the TM1Top issue. I was hoping it was a simple issue.
Posted: Thu Nov 10, 2016 10:13 pm
by jrizk
Hi,have you copied the new ssl files to your Tm1top\ssl folder?
Posted: Fri Nov 11, 2016 11:14 pm
by Babandit
What Version of TM1 and What FP?
Posted: Wed Nov 16, 2016 1:58 pm
by PavoGa
We got it going. While not personally involved, one of the other developers kept fiddling with it and got it going. These two links were reported as being helpful:
http://www.ibm.com/developerworks/libra ... index.html
http://www-01.ibm.com/support/docview.w ... SS9RXT-_-R
I have not even looked at them, so I cannot comment on the content.
Posted: Mon Nov 21, 2016 4:55 pm
by Neil Watson
I did this at the weekend, Change the path to where your new certificates are;
we've moved to V2 certificates and had to add this line to the tm1top.ini file
AdminSvrSSLCertAuthority=\\ServerName\TM1SSL\SSLCertificates\tm1ca_v2.pem
If the certificates are in a "new" folder then you'll have to point to them even if they're not the v2 ones
Best of Luck
