The SSL break and TM1Top
- PavoGa
- Excel Version: 2013 PAW
Has anyone had trouble getting TM1Top to work with the new IBM SSL certificates? I have been unable to get it to work. No problem with Ops Console.
Ty
Cleveland, TN
Cleveland, TN
dsproffitt
- OLAP Product: All of them
- Version: All of them
- Excel Version: 2003 -2013
Re: The SSL break and TM1Top
Please post
1) What do you see (error messages)
2) What have to done to investigate the issue
Then we can make a start.
- PavoGa
"Could not connect to server "tm1instance" on admin host "servername"
Looks like our problems are all over the place. Got VMs connecting with no problem, Perspectives connects with no problem on a client laptop, but on the same client, Architect will display the instances and not allow a login (click on the instance, get a spinning circle for a few seconds, then nothing).
We're getting all the other problems straightened out and maybe that will correct the TM1Top issue. I was hoping it was a simple issue.
Ty
Cleveland, TN
Cleveland, TN
jrizk
- OLAP Product: Tm1
Hi,have you copied the new ssl files to your Tm1top\ssl folder?
J.Rizk
Tm1 for everyone
Tm1 for everyone
Babandit
What Version of TM1 and What FP?
- PavoGa
We got it going. While not personally involved, one of the other developers kept fiddling with it and got it going. These two links were reported as being helpful:
http://www.ibm.com/developerworks/libra ... index.html
http://www-01.ibm.com/support/docview.w ... SS9RXT-_-R
I have not even looked at them, so I cannot comment on the content.
Ty
Cleveland, TN
Cleveland, TN
Neil Watson
- Version: 6 and 2.5 to 10.2.2
- Excel Version: 2007 2010
I did this at the weekend, Change the path to where your new certificates are;
we've moved to V2 certificates and had to add this line to the tm1top.ini file
AdminSvrSSLCertAuthority=\\ServerName\TM1SSL\SSLCertificates\tm1ca_v2.pem
If the certificates are in a "new" folder then you'll have to point to them even if they're not the v2 ones
Best of Luck
Best of Luck
