Issues with FP 6 and Client app access
Posted: Fri Sep 30, 2016 8:14 pm
by Jefflinde
Hello, i apologize in advance as I am super new to TM1. My company has an on-prem solution running 10.2.2 FP3 and I upgraded the Dev server to FP6. Everything went great and I can access our model from the server and via the web based applications. The client side applications like Architect and Perspectives are where I am having issues. Is there a client side update that accompanies FP6 or is there something else that i am missing. I read through the release information and didn't see anything about a client upgrade but I could have easily missed something.
thank you in advance for your help.
Jeff
Re: Issues with FP 6 and Client app access
Posted: Fri Sep 30, 2016 8:21 pm
by jwilkins
FP 6 switched to using TLS 1.2 for communication and rejects all pre TLS 1.2 communication. You need to either update the clients to FP 6 as well, or enable pre-TLS 1.2 support. To support old clients set the parameter SupportPreTLSv12Clients to T in your tm1s.cfg file.
Here's the relevant documentation: http://www-01.ibm.com/support/docview.w ... wg27048181
Posted: Fri Sep 30, 2016 8:42 pm
by Jefflinde
Thank you so much for the response.
