how to restrict user input using macros in Excelladdin
ranga
- OLAP Product: COGNOSTM1, Cognos
HI Team ,
i want restrict user input negative value into excel template using macros .
Please help your inputs
- jim wood
- Version: PA 2.0.7
Re: how to restrict user input using macros in Excelladdin
Moved to the correct forum.
ranga
Thanks for reply
i am new to this portal . please tell me which group we can keep this post
This subforum is fine, Jim moved the topic for you.
RJ!
If I'm reading that right, I think you need to have code against an "On Change" procedure in your Excel Template that monitors the cells your looking at...ranga wrote:HI Team ,
Though if it was me, I'd just use Data Validation in Excel to restrict a user from inputting anything "Less then 0" in your form
The event in VBA is called Worksheet_Change event.
You will find thousands of code samples on the internet with a search action.
However, as said above, there are better ways to tackle this requirement.
jduplessis
Another alternative is using sell locking and protecting the sheet. We use this a lot because it also works in TM1 web, unlike VBA alternatives.
How does his restrict the input of negative values ?jduplessis wrote:Another alternative is using sell locking and protecting the sheet
jduplessis
Ah, I stopped reading at restrict values... technically I suppose not being able to enter any value would include not being able to enter negative values, but not the intended outcome...Wim Gielis wrote:How does his restrict the input of negative values ?jduplessis wrote:Another alternative is using sell locking and protecting the sheet
Let's give READ access to everyone and we will never ever suffer from bad inputjduplessis wrote:Ah, I stopped reading at restrict values... technically I suppose not being able to enter any value would include not being able to enter negative values, but not the intended outcome...Wim Gielis wrote:How does his restrict the input of negative values ?jduplessis wrote:Another alternative is using sell locking and protecting the sheet
ranga
Thanks all for your reply
