how to restrict user input using macros in Excelladdin
ranga
OLAP Product: COGNOSTM1, Cognos
Post by ranga »
HI Team ,
i want restrict user input negative value into excel template using macros .
Please help your inputs
jim wood
Version: PA 2.0.7
Re: how to restrict user input using macros in Excelladdin
Post by jim wood »
Moved to the correct forum.
ranga
Post by ranga »
Thanks for reply
i am new to this portal . please tell me which group we can keep this post
This subforum is fine, Jim moved the topic for you.
RJ!
Post by RJ! »
ranga wrote:HI Team ,
If I'm reading that right, I think you need to have code against an "On Change" procedure in your Excel Template that monitors the cells your looking at...
Though if it was me, I'd just use Data Validation in Excel to restrict a user from inputting anything "Less then 0" in your form
The event in VBA is called Worksheet_Change event.
You will find thousands of code samples on the internet with a search action.
However, as said above, there are better ways to tackle this requirement.
jduplessis
Post by jduplessis »
Another alternative is using sell locking and protecting the sheet. We use this a lot because it also works in TM1 web, unlike VBA alternatives.
jduplessis wrote:Another alternative is using sell locking and protecting the sheet
How does his restrict the input of negative values ?
jduplessis
Ah, I stopped reading at restrict values... technically I suppose not being able to enter any value would include not being able to enter negative values, but not the intended outcome...
Let's give READ access to everyone and we will never ever suffer from bad input :-D
ranga
Post by ranga »
Thanks all for your reply
