Mix Dynamic Subset with Static Ones
Posted: Mon Oct 19, 2015 1:02 am
by macsir
Hi, All
I just noticed if I created one static subset based on the mixed dynamic subsets and static subsets. I can use the parent without any problem for the day and all children are there. But if the server restarts, that parent static subset will automatically exclude the dynamic child subsets, which means only static children are left. The dynamic children are simply not included in that parent.
Does anyone have same situation? I am on 10.2.2.
Re: Mix Dynamic Subset with Static Ones
Posted: Thu Oct 22, 2015 11:13 am
by Wim Gielis
macsir wrote:Hi, All
Honestly, I don't understand what you are telling here.
Can you provide step by step instructions to reproduce the problem, with a dummy dimension for example ?
If not, I bet you will not get a lot of valuable feedback.
Thanks.
Posted: Thu Oct 22, 2015 10:40 pm
by macsir
Ok, here is the example.
Default is dynamic subset and FY 2004 Budget is the static. I created a static parent Subset1 to include both. After server restarts, the Subset1 only has FY 2004 Budget left.
Posted: Thu Oct 22, 2015 10:43 pm
by macsir
after restarts
Posted: Thu Oct 22, 2015 10:49 pm
by macsir
I think the reason is just because the parent is static anyway.
Posted: Fri Oct 23, 2015 1:19 pm
by Wim Gielis
I see what you mean. But I cannot reproduce it. After server restart, everything is the same as before.
I am on 10.2.2 FP4, if that matters.
Posted: Mon Oct 26, 2015 12:26 am
by macsir
Thanks, Wim
We are not in the latest FP4 yet. And I will try it later and post it.
Posted: Mon Oct 26, 2015 7:06 pm
by Wim Gielis
Okay, thanks for keeping us informed.
Posted: Mon Nov 02, 2015 6:50 am
by macsir
Yes, Wim. The FP4 fixed this issue.
Posted: Wed Nov 04, 2015 3:43 am
by Wim Gielis
Thank you for confirmation macsir.
