Sum in TM1 Rules based on Attribute
Posted: Tue Sep 08, 2015 1:54 pm
Morning
In an ccount dimension, I would like to do a KPI which sum others account depending on the attribute.
By exemple
Dimension Account
Acc1 Attr1 Value : 10
Acc2 Attr2 Value : 30
Acc3 Attr1 Value : 40
Acc4 Attr1 Value 50
KPI based on Attr1 : 100
I have the following idea :
Solution 1 Use TM1 Rules with an IF and the function consolidatechildren but I think I will an issue with the performance
Solution 2 : Declare in performance modeler all the account in the dimension and have KPI : Acc1+Acc2+Acc4
Solution 3 : Do a subset with MDX and have a rollup
Solution 4 : Use a TI Process to do so
My client wants to have something dynamic which mean each time I change the attribute of the account dimension the calculation is redone automaticly
Any other solution in mind
thanks you
By exemple
Dimension Account
Acc4 Attr1 Value 50
thanks you
