Sum in TM1 Rules based on Attribute
ARNOJ
Excel Version: 2010 SP1
Post by ARNOJ »
Morning
In an ccount dimension, I would like to do a KPI which sum others account depending on the attribute.
By exemple
Dimension Account
Acc1 Attr1 Value : 10
Acc2 Attr2 Value : 30
Acc3 Attr1 Value : 40
Acc4 Attr1 Value 50
KPI based on Attr1 : 100
I have the following idea :
Solution 1 Use TM1 Rules with an IF and the function consolidatechildren but I think I will an issue with the performance
Solution 2 : Declare in performance modeler all the account in the dimension and have KPI : Acc1+Acc2+Acc4
Solution 3 : Do a subset with MDX and have a rollup
Solution 4 : Use a TI Process to do so
My client wants to have something dynamic which mean each time I change the attribute of the account dimension the calculation is redone automaticly
Any other solution in mind
thanks you
Please note that English is not my native language.
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Re: Sum in TM1 Rules based on Attribute
Post by AmbPin »
Depends on how the "client" is changing the attribute but my preference would be for an alternative dimension hierarchy.
ARNOJ
Post by ARNOJ »
Like each client say it is "not often" but we all know what it means
yes the parallel hiearchy based on the attributs
RJ!
Post by RJ! »
Not an immediate solution, but I think the new Attribute Hierarchies might resolve this for you without rules.
I'm sure I'll be quickly corrected but I think that will be in FP4 that is due this month...
Go for the classic solution in this area:
- allow the client to change the attributes (for instance, create an active form)
- add a process with an Action button that recreates the hierarchy based on the attribute values.
DimensionElementComponentDelete and DimensionElementComponentAdd will do the majority of the work in TI.
- the client clicks on the button and can review the new results
Wim
