All,
We are designing a new TM1 Model in 10.2.2, for most of the TM1 objects there is a corresponding object with an extension Analysis Services Dimension in the data base directory. Here I have attached the screen shot, Any pointers what these objects are and how are they created ..?
Any pointers in terms of maintenance.
Radhika
TM1 10.2.2 - Analysis Service Dimension
Radhika
- Version: v9.4.1
- Excel Version: Microsoft Excel 2003
- Analysis Services Dimension.png (65.96 KiB) Viewed 4308 times
failurehappening
Re: TM1 10.2.2 - Analysis Service Dimension
I think the problem is that you have Microsoft Analysis services installed as past of SQL server. This is picking up the file association from the .dim file. Right click on the file and select "Open With..." then select another application that you want to open the file with. Personally, I open nearly all my TM1 objects with Notepad++, even the binary objects like dimensions and cubes as you can get insights by opening with a text viewer. Make sure you select an application that does not lock the file when opening...
RHR
Radhika
- Version: v9.4.1
Got it, thank you for your prompt response.
