May I know how to solve the problem below
Problem:
The system showed the following message when I opened Cognos Configuration (cogconfig.sh)
Action Taken:A fatal error occurred. Unable to run the application.
An exception occurred.
java.lang.UnsatisfiedLinkError: JCAM_Crypto_JNI (0509-022 Cannot load module ../bin64/libJCAM_Crypto_JNI.so.
0509-026 System error: Cannot run a file that does not have a valid format.)
You should re-install the software.
- Read the installation guide (actually, few relating to AIX)
Installed the TM1 on AIX (issetup.sh)
Set the JAVA_HOME environment variable (etc/profile) (Java6)
Read the "reference"
Add the tm1_64/bin64 path to PATH environment variable (does not contain any path relating to tm1 before)
Fatal error on starting Cognos Configuration after installing IBM Cognos BI 10.1.1 Fix Pack 1
http://www-01.ibm.com/support/docview.w ... wg21610845
Unable to run cogconfig.sh: Can't find library JCAM_Crypto_JNI
http://www-01.ibm.com/support/docview.w ... wg21341921
After installing IBM Cognos 10.2 TM1 client, error JCAM_Crypto_JNI.dll is not a valid Win32 application is seen when attempting to open Cognos Configuration
http://www-01.ibm.com/support/docview.w ... wg21695920
