TM1 on AIX - Cognos Configuration - A fatal error occurred
wilsonmax
Version: 10.1.0
Post by wilsonmax »
Does anyone 8-) here familiarize with TM1 on AIX server :?:
May I know how to solve the problem below :?:
Problem:
The system showed the following message when I opened Cognos Configuration (cogconfig.sh)
A fatal error occurred. Unable to run the application.
An exception occurred.
java.lang.UnsatisfiedLinkError: JCAM_Crypto_JNI (0509-022 Cannot load module ../bin64/libJCAM_Crypto_JNI.so.
0509-026 System error: Cannot run a file that does not have a valid format.)
You should re-install the software.
Action Taken:
  • Read the installation guide (actually, few relating to AIX)
    Installed the TM1 on AIX (issetup.sh)
    Set the JAVA_HOME environment variable (etc/profile) (Java6)
    Read the "reference"
    Add the tm1_64/bin64 path to PATH environment variable (does not contain any path relating to tm1 before)
Reference:
Fatal error on starting Cognos Configuration after installing IBM Cognos BI 10.1.1 Fix Pack 1
http://www-01.ibm.com/support/docview.w ... wg21610845
Unable to run cogconfig.sh: Can't find library JCAM_Crypto_JNI
http://www-01.ibm.com/support/docview.w ... wg21341921
After installing IBM Cognos 10.2 TM1 client, error JCAM_Crypto_JNI.dll is not a valid Win32 application is seen when attempting to open Cognos Configuration
http://www-01.ibm.com/support/docview.w ... wg21695920
wilsonmax
Version: 10.1.0
Re: TM1 on AIX - Cognos Configuration - A fatal error occurr
Post by wilsonmax »
Solution
It was discovered that the java at JAVA_HOME is 32-bit.
The above problem is solved after:
  • Installing Java7_64
    Changing the JAVA_HOME
    Changing the TM1 Server Instance path to the actual mount point
Another problem:
My TM1 Architect could show the TM1 Servers but could not login to them. :shock: :roll:
Solution
Make sure all the following port numbers have been opened:
  • 5495 - TM1 Admin Host
    5498 - TM1 SSL Server
    12399 - TM1 Models 1
    45557 - TM1 Models 2
    9510 - TM1 Web
