Hi Everyone
Can someone please assist me.
I am running TM1 9.1 SP4 on Microsoft Server 2003 operating system.
After installing TM1 web on the same computer I am unable to see the server in excel when acessing the server from an workstation.
Thank you
Moderator note: This thread has been moved from the Bugs forum. This is not a bug; a bug is where the software does not perform as documented, and which affects all users of that version in a reproducable fashion.
Ms Excel Unable to see server when TM1 web is installed
- Version: 9.1
- Excel Version: 2003
Re: Ms Excel Unable to see server when TM1 web is installed
Apologies if this comes under the "too obvious" category, but the installation would probably have shut down both the TM1 server service and the TM1 Admin Hose service. You've checked that both of those are in fact up and running?MC Dippenaar wrote: Can someone please assist me.
Also I'd be inclined to reboot the box if possible after an installation like that. Server 2003 is fairly robust in my experience and will accept new software quite happily (well, TM1 anyway) but it's often wise to take the precaution.
- Version: 9.1.4 FP1
i assume that the config's are correct.
execute importsslcert.exe in bin\ssl
also check %windir%\system32\drivers\etc\services
if there are the correct port entries for the tm1adminsrv_ssl & tm1adminsvr
