I have integrated TM1 ( 10.2.2) and BI ( 10.2) to use CAM authentication
BI Environment: It is a distributed environment ( Windows 2008 R2 ). BI set up is there on seven different boxes - Content Store, Gateway, Reporting 1, Reporting 2. Reporting 3, Reporting 4, Reporting 5
TM1 Environment: Single Server Installation on Windows 2008 R2
Integrated Mode: 5
Issue:When I try to access Performance Modeler as desktop client , I get the error message attached. PM works fine from Applications web. I do not get this message when I try to connect to Planning Sample, this happens only when I try to connect developer defined tm1 server.
Please help me to fix this issue
Radhika
TM1 performance Modeler - Unable to connect to the TM1 Serve
Radhika
- Version: v9.4.1
- Excel Version: Microsoft Excel 2003
- Error Message.docx
- (89.63 KiB) Downloaded 715 times
