Server Crash Error Messages
Version: PA 2.0.7
Post by jim wood »
Guys,
One of servers crashed today and we got the following error messages in the day before it went down:
55 ERROR 2009-06-16 08:49:46,015 TM1.Blob StringRead - Read failed: 1
15 WARN 2009-06-15 06:11:28,088 TM1.Server TM1ServerImpl::FileSave could not reacquire lock on object with index 0x40000003
15 WARN 2009-06-15 06:11:28,088 TM1.Server TM1ServerImpl::FileSave could not reacquire lock on object with index 0x40000004
15 WARN 2009-06-15 06:11:28,088 TM1.Server TM1ServerImpl::FileSave could not reacquire lock on object with index 0x40000005
15 WARN 2009-06-15 06:11:28,088 TM1.Server TM1ServerImpl::FileSave could not reacquire lock on object with index 0x40000006
15 WARN 2009-06-15 06:11:28,088 TM1.Server TM1ServerImpl::FileSave could not reacquire lock on object with index 0x40000007
15 WARN 2009-06-15 06:11:28,088 TM1.Server TM1ServerImpl::FileSave could not reacquire lock on object with index 0x40000008
15 ERROR 2009-06-15 06:11:28,094 TM1.Process Process "00 save data": Execution was aborted. Error file: <tm1processerror_20090615061128_00 save data.log>
Any ideas?????
Server: Fujitsu Solaris 10
Software Version 9.1 SP3 U2
It crashed while I was trying to complete a data export,
Jim.
Shop at Amazon
Steve Vincent
Version: 10.2.2 FP1
Re: Server Crash Error Messages
Post by Steve Vincent »
Most messages on Windows are next to useless, but some of the Unix stuff looks almost helpful, like it might be trying to save stuff and couldn't. I assume you have plenty of disk space?
Martin Ryan
Post by Martin Ryan »
Any chance of a conflict with anti virus software? Perhaps this software was kicking off as you happened to trying to write to the cubes?
Version: PA 2.0.7
Post by jim wood »
Thanks for the replys guys. There was plenty of disk space on the allocated mount. As for virus software I'm not sure. We share our box with a piece of software called debt manager. It may have something to do with that. I will investigate further........
Shop at Amazon
Martin Erlmoser
OLAP Product: TM1, Cognos Express,..
Version: 9.1.4 FP1
Post by Martin Erlmoser »
if you do the export again i think it won't crash, right?
Version: PA 2.0.7
Post by jim wood »
I did do the export again but slightly differently:
1) I cleared some historic data out of a cube to make sure that enough memory was available.
2) I mad my dimension selections more compact. (Even though ignore consolidations was ticked I removed them all manually anyway)
Due to both of the above I guess it's diffcult to say that I was not able to replicate. I kind of guess it means I was able to work my way around it,
Jim.
Shop at Amazon
paulsimon
Version: PA 2.0.5
Post by paulsimon »
Jim
We get those all the time. What version are you on - 9.1 by any chance? Apparently it is a bug when TM1 is saving data to disk. Cognos say that the save data is still working, but it is producing spurious messages. Personally I am not convinced, as I have had too many cases of things that I could have sworn I had saved, when then don't seem to have changed after the nightly restart of the TM1 service.
This is apparently cured in 9.4.
Paul
Version: PA 2.0.7
Post by jim wood »
Sounds about right. Cheers Paul,
Jim.
Shop at Amazon
