Hi Everyone,
How do you make sure that whoever runs the TI Process does not enter a decimal value in the parameter prompt in tm1 ?
What I’m thinking is doing a check in Prolog, using iF statement. I’d like to do ProcessQuit if user types in a decimal value. But I can’t think of a function that detects decimal value in parameter and then return a 1 or 0.
Verify the integer value in parameter
Re: Verify the integer value in parameter
Just compare the parameter value to the return value of the Int(Parameter) function. If they're the same you're good to go, if they're not you quit.elee123 wrote:Hi Everyone,
elee123
- OLAP Product: tm1
Thanks Alan. You've been helpful.
