Verify the integer value in parameter
elee123
OLAP Product: tm1
Post by elee123 »
Hi Everyone,
How do you make sure that whoever runs the TI Process does not enter a decimal value in the parameter prompt in tm1 ?
What I’m thinking is doing a check in Prolog, using iF statement. I’d like to do ProcessQuit if user types in a decimal value. But I can’t think of a function that detects decimal value in parameter and then return a 1 or 0.
Re: Verify the integer value in parameter
elee123 wrote:Hi Everyone,
Just compare the parameter value to the return value of the Int(Parameter) function. If they're the same you're good to go, if they're not you quit.
elee123
OLAP Product: tm1
Post by elee123 »
Thanks Alan. You've been helpful.
