Same name in two dimesions
kiss351523
Version: 9.5
Excel Version: 2007 and 2003
Post by kiss351523 »
How to write the TM1 Rules, when same element name in two dimensions in one cube?
rmackenzie
Re: Same name in two dimesions
Post by rmackenzie »
You simply clarify the dimension name using this syntax:
['dim1':'element', 'dim2':'element'] = N: ...
Robin Mackenzie
rmackenzie wrote:You simply clarify the dimension name using this syntax:
Wow; you got to that one fast.
This if course is also a FAQ. (Rules section, last item of the "Rules In General" group.) Hence the Request For Assistance Guideline (#6) to always consult the FAQ before posting a question.
