How to write the TM1 Rules, when same element name in two dimensions in one cube?
Same name in two dimesions
- Version: 9.5
Re: Same name in two dimesions
You simply clarify the dimension name using this syntax:
['dim1':'element', 'dim2':'element'] = N: ...
Robin Mackenzie
Wow; you got to that one fast.rmackenzie wrote:You simply clarify the dimension name using this syntax:Code: Select all
This if course is also a FAQ. (Rules section, last item of the "Rules In General" group.) Hence the Request For Assistance Guideline (#6) to always consult the FAQ before posting a question.
