Pivoting Measures
Posted: Fri May 02, 2014 11:01 am
by RSK
Morning all,
I have a query about whether it's possible to pivot the measures used within a cube to export these as a single row of data in columns rather than a row for each measure?
At the moment I have 2 measures in the cube, Recharge Amount and a Comment string element. When exporting the data via asciioutput I get a row for each measure, is this even possible? In my head it should be easy but I'm failing miserably!
Re: Pivoting Measures
Posted: Fri May 02, 2014 11:05 am
by Alan Kirk
Use the Recharge Amount (
only the recharge amount) in the subset that is used as part of the source view. In the Data tab, write a CellGetS function to retrieve the corresponding Comment value. Now you can write both out to the text file in the one line.
Posted: Fri May 02, 2014 11:08 am
by RSK
Thank you so much Alan, much appreciated.
