Morning all,
I have a query about whether it's possible to pivot the measures used within a cube to export these as a single row of data in columns rather than a row for each measure?
At the moment I have 2 measures in the cube, Recharge Amount and a Comment string element. When exporting the data via asciioutput I get a row for each measure, is this even possible? In my head it should be easy but I'm failing miserably!
Pivoting Measures
Re: Pivoting Measures
Use the Recharge Amount (only the recharge amount) in the subset that is used as part of the source view. In the Data tab, write a CellGetS function to retrieve the corresponding Comment value. Now you can write both out to the text file in the one line.RSK wrote: I have a query about whether it's possible to pivot the measures used within a cube to export these as a single row of data in columns rather than a row for each measure?
RSK
- OLAP Product: TM1 10.1.1
- Version: TM1 10.1.1
Thank you so much Alan, much appreciated.Alan Kirk wrote:Use the Recharge Amount (only the recharge amount) in the subset that is used as part of the source view. In the Data tab, write a CellGetS function to retrieve the corresponding Comment value. Now you can write both out to the text file in the one line.RSK wrote: I have a query about whether it's possible to pivot the measures used within a cube to export these as a single row of data in columns rather than a row for each measure?
