I have problem with security in CX 10.2.
When i deploy application (not central), element security doesn't work. By this i mean element security on other dimensions not on aprooval.
For example. If i create Element security cube and write rule on dimension:
['January']=S:'READ';
It only works if i lock this element via Element Properties?
Any advice?
Thank you
Security problem in Cognos Express 10.2
Re: Security problem in Cognos Express 10.2
It isn't going to work for an administrator. Also, you have to refresh security after writing the rule. Have you done that?
