TM1 Performance Modeler 10.2.0.0 problem.
Posted: Sat Apr 19, 2014 5:08 pm
Dear all,
I installed TM1 10.2 on Windows 7 32-bit. When I tried to access TM1 Performance Modeler first time, I failed.
At the "Connect to IBM Cognos TM1 system" window I added http://server_name:9510/pmpsvc/services, there was only one button available "Log on as" and gives me an error message after pressing: "Unable to login to the planning server, the TM1 server may be unavailable. The application will now exit."
The same time Architect, tm1web, Cognos Insight are available.
What should I do?
Thank you.
What should I do?
Thank you.
