TM1 server error while starting
mincharug.shulft
OLAP Product: Applix,Cognos TM!
Version: applix9.0Cognos tm1 9.5.1
Excel Version: Excel 2010 2007
Post by mincharug.shulft »
Please find the attached issue and really appriciated if anyone can help me?
tm1 version is 10.1.1
Tm1 server error while starting.docx
(14.93 KiB) Downloaded 264 times
Re: TM1 server error while starting
9 times out of 10 with a failed service installation I would look at the config file but in your specific case the first thing that jumped out at me is:
OpenSCManager failed - (0x5) Access is denied.
My first port of call in this case would be to check and see if the config manager has access to install a service, I am assuming you just double-clicked and opened it up, I would recommend a right-click run as admin to see what happens.
mincharug.shulft
hello declanr:
Thanks for your reply .i think your not got my query.
when iam starting after recreated the "Tm1 server instance" from IBM cognos configuration ia m getting the that attached error.
Pls let me know if your still didnot understand.
Version: PA 2.0.7
Post by jim wood »
I've had issues in the past with windows services. Recreating a service doesn't awlays work as it should. Remove it and then make sure that the service has been fully removed in the registry. Then create a new empty service and drop your CFG file in. Amend the CFG and if your service doesn't start then it's a setting issue. If it does start, drip feed your files in to eliminate any corrupt files. Hopefully by the end of all this you'll have a working service.
