Hi Alan.Alan Kirk wrote:
Off the top of my head I can't think of anything that's (shall we say) "region-sensitive" in the tool itself, but it could be the result of a mismatch between the client settings and the server-side settings, especially given that it works when your regional settings (I presume that you mean on the client side) are in English/US. What's the language of the box that the server is running on?
I'll do some further tests and see what I can find.
Yes, it is on the client side, but it doesn't change anything if I do the same on the server.
If you want to reproduce it, you only need to change the regional setting on your clientmachine to Danish, and then try to copy a range of 2 cells with 6,50 into a slice.
If you need more info please say so.
