I am doing exactly waht smorgan is. Using a combination of techniques as advised herein by others, you should be able to get it going fairly quickly. Incude:
Screenupdating=false
Recalc mode=manual and do strategic calcs only where necessary
Create a new workbook for each iteration
Proper VIEW() functions for DBRW()
Here's my VBA code for the outer and inner loops (x200).
It uses a central error handler and a form to get the user choices, so adapt as needed. Maybe it'll help...
'Look down the hierarchy and create a PDF
'report for every N-level TM1 element
Public Function gbCreatePDFs(Optional ByVal bSelected As Boolean) As Boolean
    Const sSource As String = "gbCreatePDFs()"
    Dim bReturn As Boolean
    Dim rngCell As Range, lCalculation As Long
    Dim iPDFCount As Integer, iPDFCounter As Integer
    Dim frmPDF As FPDF
    On Error GoTo ErrorHandler
    bReturn = True
    lCalculation = Application.Calculation
    Application.Calculation = xlCalculationManual
    Application.ScreenUpdating = False
    'Test whether TM1 add-in is loaded
    Application.Run "TM1RECALC1"
    'If selected reports only, (passed boolean optionally),
    'show a form for user to select reports to create.
    'For each one selected, produce a new report.
    'Otherwise loop all elements.
    Set frmPDF = New FPDF
    With frmPDF
        'Populate the form list with elements to select from
        If Not .gbPopulateList() Then Err.Raise glHANDLED_ERROR
        .Show
        If .UserCancel Then
            Err.Raise glUSER_CANCEL
        Else
            'Grab the selections into a local array
            'arrSelectedReports = .Selections
            Set mrngCellsToTest = .SelectionRange
        End If
    End With
    wksMaster.Activate
    'Add a backslash to the output folder string if necessary.
    msOutputFolderPDF = wksControl.Range("PDFOutputFolder").Value
    msOutputFolderExcel = wksControl.Range("ExcelOutputFolder").Value
    If Right(msOutputFolderPDF, 1) <> "\" Then
        wksControl.Range("PDFOutputFolder").Value = msOutputFolderPDF & "\"
    End If
    'Get the number of PDFs so we can show progress to the user.
    iPDFCount = mrngCellsToTest.Rows.Count
    'Loop through cells and create pdfs where indicated.
    For Each rngCell In mrngCellsToTest.Cells
        iPDFCounter = iPDFCounter + 1
        Application.StatusBar = "Creating " & rngCell.Value & _
                              " PDF, " & iPDFCounter & " of " & iPDFCount & "..."
        'Select the CC item in the pick list.
        If Not mbCreatePDF(rngCell.Value) Then Err.Raise glHANDLED_ERROR
    Next rngCell
    'Report finished.
    MsgBox "Finished creating PDF reports.", vbInformation + vbOKOnly
ProcExit:
    gbCreatePDFs = bReturn
    'Restore environment.
    Application.Calculation = lCalculation
    Application.ScreenUpdating = True
    Application.StatusBar = ""
    Application.DisplayAlerts = True
    Exit Function
ErrorHandler:
    bReturn = False
    If Err.Number = 1004 Then
        MsgBox "Please check that you are logged in to TM1", vbExclamation + vbOKOnly, "TM1 Load Error"
    End If
    If gbCentralErrorHandler(msMODULE, sSource) Then
        Stop
        Resume
    Else
        Resume ProcExit
    End If
End Function
'CREATE A PDF REPORT FOR THE PASSED COST CENTRE
Private Function mbCreatePDF(ByVal sCostCentre As String) As Boolean
    Const sSource As String = "mbCreatePDF()"
    Dim bReturn As Boolean, wkbNew As Workbook, rngStart As Range
    bReturn = True
    'Enter the Cost Centre and recalculate.
    wksMaster.Activate
    wksMaster.Range("Expense_Cost_Centre").Value = sCostCentre
    Application.Run "tm1recalc1"
    'Only produce a report where there are some numbers.
    If Not mbAllCellsAreZero Then
        UnhideZeroRows
        'Copy the result to a new workbook, value copy everything,
        'then hide rows and export as PDF
        Set rngStart = wksMaster.Range("HideRowStart")
        'Create a new workbook
        wksMaster.UsedRange.Copy
        Set wkbNew = Workbooks.Add
        'Copy the whole of master
        With ActiveSheet
            .Paste
            'PasteSpecial to copy column widths
            .Range("A1").PasteSpecial Paste:=xlPasteColumnWidths, Operation:=xlNone, SkipBlanks _
        :=False, Transpose:=False
            'PasteSpecial to remove formulas
            .UsedRange.Copy
            .Range("A1").PasteSpecial Paste:=xlPasteValues
            'Copy the hiderow start range
            rngStart.Copy _
                    Destination:=.Range(Mid(rngStart.Name.RefersTo, 9, 10))
            .Range(Mid(rngStart.Name.RefersTo, 9, 10)).Name = "HideRowStart"
            'Hide the check total row
            .Rows(gs_ROW_CHECKTOTAL).Hidden = True
            'Delete the TM1 header area.
            .Rows(gs_ROWS_HEADER).Delete Shift:=xlUp
            'Hide blank/zero rows
            If Not gbHideZeroRows(False) Then Err.Raise glHANDLED_ERROR
            'Set the print parameters.
            With .PageSetup
                .CenterFooter = "Page &P of &N"
                .Orientation = xlLandscape
                .Zoom = False
                .FitToPagesWide = 1
                .FitToPagesTall = 20
                .PrintTitleRows = gs_ROWS_PRINT_TITLES
            End With
            'Produce PDF
            .ExportAsFixedFormat _
                    Type:=xlTypePDF, _
                    Filename:=wksControl.Range("PDFOutputFolder").Value & Replace(sCostCentre, "/", "-") & ".pdf"
        End With
        Application.DisplayAlerts = False
        wkbNew.Saved = True
        wkbNew.Close SaveChanges:=False
    End If
ProcExit:
    Set wkbNew = Nothing
    mbCreatePDF = bReturn
    Exit Function
ErrorHandler:
    bReturn = False
        Stop
        Resume
    Else
        Resume ProcExit
    End If
End Function
