I use Windows Vista Business 32 bit and TM1 9.4.1. I have TM1 workflow installed
When I try to load my workflow or load the workflow console i get message
"compile error in hidden module: frmTaskActions"
What I have done is:
Uninstall MS patch KB960715 and reinstall workflow but that does not help
Andre
TM1 Workflow: compile error in hidden module: frmTaskActions
Re: TM1 Workflow: compile error in hidden module: frmTaskActions
I thought this one sounded familiar:andre lie wrote:I use Windows Vista Business 32 bit and TM1 9.4.1. I have TM1 workflow installed
http://forums.olapforums.com/viewtopic. ... 740&p=9073
Thanks Alan,
I tried the suggestion on that link. I change the compatibility flags for {0ECD9B64-23AA-11D0-B351-00A0C9055D8E} DWORD to 0 (it is the only key among four keys mentioned that have the compatibility flags)
Now I can click Admin button to open TM1 Workflow Administration Console and other buttons BUT the 'Load' button
When I click the Load button, i get this message:
- workflow error1.jpg (27.44 KiB) Viewed 7724 times
TheerapatC
- OLAP Product: Cognos
- Version: TM1
- Excel Version: 2003
UnInstall Windows Update (KB973346)
Otherwise TM1 Workflow will not work properly.
I uninstall KB973346 but still get the same error message when i click the Load button
Rgds
Rgds
- rodrigo
- OLAP Product: TM1, Executive Viewer
- Version: 9.4 MR1 with FP3
Mmmh never installed TM1 on vista, but on the IBM link of the fix pack 2 it says:
"There were no new corrections for TM1 Workflow 9.4.1 since FP1 but there were changes made in TM1 Workflow 9.4.1 FP1."
Maybe you should use the latest fix pack and/or reinstall if you havent before. the frmTaskActions problem seems to be solved with the regedit key you changed.
