Amount not seen during Zero Suppression
appleglaze28
Post by appleglaze28 »
I'd like to ask why values dervied using IF statement where the value being compared is a string?
This is the rules I got for the IF statement:
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='1st 8 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '1st 8 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='9 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '9 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='10 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '10 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='11 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '11 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='12 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '12 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='13 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '13 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='14 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '14 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='15 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '15 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='16 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '16 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='17 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '17 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='18 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '18 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='19 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '19 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='20 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '20 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='21 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '20 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='22 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '20 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='23 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '20 Hours', 'Actual Rate'), continue);
['Amount' ] = N: IF (DB('plan_manpower_cost', !base_day_month, !base_year, !base_version, !base_service_type, 'Hours Status')@='24 Hours',DB('staging_sevice_hour_type_rate', !base_day_month, !base_year, !base_version, !base_service_type, '20 Hours', 'Actual Rate'), continue);
Steve Vincent
Version: 10.2.2 FP1
Re: Amount not seen during Zero Suppression
Post by Steve Vincent »
do you have any feeders for those statements?
jim wood
Version: PA 2.0.7
Post by jim wood »
Makes sense. Over feeding would cause something like that.
kpk
OLAP Product: TM1, CX
Version: TM1 7x 8x 9x 10x CX 9.5 10.1
Excel Version: XP 2003 2007 2010
Post by kpk »
jim wood wrote:Makes sense. Over feeding would cause something like that.
Over feeding does not cause this.
But under feeding (lack of necessary feeders).
Best Regards,
Peter
kpk
Post by kpk »
This it a lack of feeder issue.
You can see it from the 'Amount' of January.
It is 0 on your screenshot and you have only N level rules for the Amount dimension element.
Best Regards,
Peter
jim wood
Version: PA 2.0.7
Post by jim wood »
Indeed thanks for the correction. I mis-read the question. A school boy error on my part, still we all make em.
appleglaze28
I'm still not too familiar how feeder regarding IF statement is written especially that the IF statement result is a String
kpk
Post by kpk »
IF does not matter.
Try the following statement:
['Number of employee']=>['Amount'],['TOTAL COST'];
This Feeder statement tells TM1 to calculate ['Amount'] and ['TOTAL COST'] measures when ['Number of employee'] is not 0.
Peter
Best Regards,
Peter
