Fixate row/column header width in a cube view using PAfE
DanielaD
Version: PA Local 2.0.9.19
Excel Version: Office 365 32bit
Post by DanielaD »
Hi, is there a possiblity to fixate the row/column header in a cube view in PAfE?
As soon as I drill in the hierarchies in my row or columns, the column width always jumps back to a small size which does not show the whole text of the elements.
Example:
In this view I adjusted the first column so that I can read the whole text:
If I now close or open a node within my hierarchy, e.g. close the node Profit before taxation normalized, the column is automatically adjusted so that I can no longer read the whole text.
In this view the first column is now automatically adjusted and I can no longer read the whole text:
Is there a possiblity to avoid this auto adjustment of this column?
We are using:
PA: 2.09.19
PASS: 2.0.96
PAW: 2.0.96
PAfE: 2.0.95.5 / 32bit
Office: O365 / 32bit
I already tried to figure it out on my own and also searched via goolge and within this forum.
Thanks a lot!
Re: Fixate row/column header width in a cube view using PAfE
Do you get the same behaviour with the view if you open in PAW using a workbench?
And if you open the view in a Book it retains the column widths?
If so, please also log a defect as I have raised this too as it seemed to come in with a recent update (possibly new formatter) and is extremely annoying.
BR, George.
Resetting column widths in a workbench is indeed a royal pain. It's very annoying.
DanielaD
Post by DanielaD »
Hi both,
I just tried in PAW and its indeed as gtonkin says.
View used in a book works fine but in a workbench I see the same behaviour.
We will log a defect at IBM.
Thanks a lot for your input!
