SubsetGetElementName loop
MarenC
Excel Version: Excel 2016
Post by MarenC »
would anyone have any idea why the following would enter into an infinite loop:
sDimName = 'Position';
sSub = 'N_Level_Position';
sDimSize = SubsetGetSize(sDimName, sSub);
sPosition = '';
nLoopcount = 1;
WHILE( nLoopcount <= sDimSize );
    sPosition = SubsetGetElementName(sDimName,sSub,nLoopcount);​
    nLoopcount = nLoopcount +1;
END;
This runs normally when I comment out sPosition inside the loop:
sPosition = '';
nLoopcount = 1;
    #sPosition = SubsetGetElementName(sDimName,sSub,nLoopcount);​
END;
Moreover and equally baffling if I add an Asciioutput under the sPosition line within the loop I get an error when saving (equal sign not found) but if I add the Asciioutput after the nLoopcount = nLoopcount +1; line within the loop it saves ok.
Maren
burnstripe
Version: 2.0.9
Re: SubsetGetElementName loop
Post by burnstripe »
Inside the while loop was the code typed in or copied and pasted in.... Might have inserted a hidden character??
Try deleting between the while loop and retyping
MarenC
Post by MarenC »
Thanks for the reply Burnstripe, that was my first thought.
I actually copied the SubsetGetElementName part from the cubewise web page as the IBM doesn't seem to be currently working. I.e. from here:
https://edu.cubewise.com/tm1-function-f ... ementname/
I did try deleting between the while loop and retyping as you suggest. I copied into notepad and back in but nothing works.
Maren
When I paste the first code in Notepad++ I see this, maybe it's the cause:
MarenC
Post by MarenC »
Hi Wim,
Many thanks, this was the issue. No idea where that came from!
I thought I had deleted everything between the loop but obviously missed that little bit.
Must have been something copied from the cubewise page.
Maren
