Hello, I need help on getting this MDX to work
In a cube view, I'm trying to set the values to be displayed for dim01, subjected to selection of dim2 element and attributes of the selected dim2 element
CURRENTMEMBER.PROPERTIES work fine but CURRENTMEMBER.PROPERTIES().PROPERTIES() doesn't work.
TM1SubsetToSet([dim01] ,
IIF([dim02].CURRENTMEMBER.PROPERTIES("att1").PROPERTIES("att2") = "xxx" , "subset_a" ,
IIF([dim02].CURRENTMEMBER.PROPERTIES("att1").PROPERTIES("att2") = "yyy" , "subset_b" , "subset_none")))
Can anyone help with the syntax.
Much appreciated!
Need help on MDX
Re: Need help on MDX
And why on earth would you expect this to work?
CurrentMember is obviously a member
CurrentMember.Properties("propertyName") returns a string
You cannot pass a string into an expression which requires a member.
From a logic perspective what you want to do can still work but you will need to wrap the first CurrentMember.Properties in a StringToMember function.
wbf
- Version: 10.2.0
- Excel Version: 2013
Thanks.
I've tried that as well - since it says invalid MDX expression I thought of just putting the simplified version which represents the idea.
IIF(StrToMember([dim02].CURRENTMEMBER.PROPERTIES("att1")).PROPERTIES("att2") = "xxx" , "subset_a" ,
IIF(StrToMember([dim02].CURRENTMEMBER.PROPERTIES("att1")).PROPERTIES("att2") = "yyy" , "subset_b" , "subset_none")))
- gtonkin
Have a look at the reference guide for more on how to use StrToMember per Lotsa's suggestion.
wbf
- Version: 10.2.0
Hi thanks for the advice. the following works
IIF(StrToMember("[dim02].["+[dim02].CURRENTMEMBER.PROPERTIES("att1")+"]").PROPERTIES("att2") = "xxx" , "subset_a" ,
IIF(StrToMember("[dim02].["+[dim02].CURRENTMEMBER.PROPERTIES("att1")+"]").PROPERTIES("att2") = "yyy" , "subset_b" , "subset_none")))
Basically, the member requires some "wrapping"
