Hold, Release Hold via Rest API or TI Process?
raeldor
OLAP Product: IBM PAW
Version: Unknown
Excel Version: 365
Post by raeldor »
Can this be done via the rest API, or even TI process?
Ray
Paul Segal
Version: TM1 11 and up
Re: Hold, Release Hold via Rest API or TI Process?
Post by Paul Segal »
Yes, see https://www.tm1forum.com/viewtopic.php?t=14399, where Wim describes how for a TI. It should be possible to do the same using the REST API as it's basically creating a control cube if it doesn't exist and then applying strings to one or more cells. See also https://www.ibm.com/docs/en/planning-an ... e-cubename and https://www.ibm.com/docs/en/planning-an ... ic=cd-hold
Paul
Paul
Here is a TI approach. The process will read a text file and apply holds to the given combinations.
In the example it will lead to 13 holds in the cube, as the combination in line 14 cannot be located in the cube.
It gives us 13 holds (red triangles) at several levels in the cube.
_Add holds.pro
(10.28 KiB) Downloaded 601 times
data.txt
(200 Bytes) Downloaded 599 times
With the code listing to generate the test cube as well, to save time for those that want to play with it:
# Cube: 'testholds'
vCube = 'testholds';
vDim1 = 'D1';
vDim2 = 'Region';
vDim3 = 'Msr';
If( CubeExists( vCube ) > 0 );
  ProcessBreak;
EndIf;
# Dimension: D1
vDim = vDim1;
# dimension creation
If( DimensionExists( vDim ) = 0 );
    DimensionCreate( vDim );
EndIf;
# inserting elements (N and C and S)
DimensionElementInsert( vDim, '', 'Alle maanden', 'C' );
DimensionElementInsert( vDim, '', '2020', 'C' );
DimensionElementInsert( vDim, '', '202001', 'N' );
DimensionElementInsert( vDim, '', '202002', 'N' );
DimensionElementInsert( vDim, '', '202003', 'N' );
DimensionElementInsert( vDim, '', '202004', 'N' );
DimensionElementInsert( vDim, '', '202005', 'N' );
DimensionElementInsert( vDim, '', '202006', 'N' );
DimensionElementInsert( vDim, '', '202007', 'N' );
DimensionElementInsert( vDim, '', '202008', 'N' );
DimensionElementInsert( vDim, '', '202009', 'N' );
DimensionElementInsert( vDim, '', '202010', 'N' );
DimensionElementInsert( vDim, '', '202011', 'N' );
DimensionElementInsert( vDim, '', '202012', 'N' );
DimensionElementInsert( vDim, '', '2021', 'C' );
DimensionElementInsert( vDim, '', '202101', 'N' );
DimensionElementInsert( vDim, '', '202102', 'N' );
DimensionElementInsert( vDim, '', '202103', 'N' );
DimensionElementInsert( vDim, '', '202104', 'N' );
DimensionElementInsert( vDim, '', '202105', 'N' );
DimensionElementInsert( vDim, '', '202106', 'N' );
DimensionElementInsert( vDim, '', '202107', 'N' );
DimensionElementInsert( vDim, '', '202108', 'N' );
DimensionElementInsert( vDim, '', '202109', 'N' );
DimensionElementInsert( vDim, '', '202110', 'N' );
DimensionElementInsert( vDim, '', '202111', 'N' );
DimensionElementInsert( vDim, '', '202112', 'N' );
# inserting parent-child relations
DimensionElementComponentAdd( vDim, 'Alle maanden', '2020', 1 );
DimensionElementComponentAdd( vDim, '2020', '202001', 1 );
DimensionElementComponentAdd( vDim, '2020', '202002', 1 );
DimensionElementComponentAdd( vDim, '2020', '202003', 1 );
DimensionElementComponentAdd( vDim, '2020', '202004', 1 );
DimensionElementComponentAdd( vDim, '2020', '202005', 1 );
DimensionElementComponentAdd( vDim, '2020', '202006', 1 );
DimensionElementComponentAdd( vDim, '2020', '202007', 1 );
DimensionElementComponentAdd( vDim, '2020', '202008', 1 );
DimensionElementComponentAdd( vDim, '2020', '202009', 1 );
DimensionElementComponentAdd( vDim, '2020', '202010', 1 );
DimensionElementComponentAdd( vDim, '2020', '202011', 1 );
DimensionElementComponentAdd( vDim, '2020', '202012', 1 );
DimensionElementComponentAdd( vDim, 'Alle maanden', '2021', 1 );
DimensionElementComponentAdd( vDim, '2021', '202101', 1 );
DimensionElementComponentAdd( vDim, '2021', '202102', 1 );
DimensionElementComponentAdd( vDim, '2021', '202103', 1 );
DimensionElementComponentAdd( vDim, '2021', '202104', 1 );
DimensionElementComponentAdd( vDim, '2021', '202105', 1 );
DimensionElementComponentAdd( vDim, '2021', '202106', 1 );
DimensionElementComponentAdd( vDim, '2021', '202107', 1 );
DimensionElementComponentAdd( vDim, '2021', '202108', 1 );
DimensionElementComponentAdd( vDim, '2021', '202109', 1 );
DimensionElementComponentAdd( vDim, '2021', '202110', 1 );
DimensionElementComponentAdd( vDim, '2021', '202111', 1 );
DimensionElementComponentAdd( vDim, '2021', '202112', 1 );
# Dimension: Region
vDim = vDim2;
EndIf;
DimensionElementInsert( vDim, '', 'World', 'C' );
DimensionElementInsert( vDim, '', 'Americas', 'C' );
DimensionElementInsert( vDim, '', 'North America', 'C' );
DimensionElementInsert( vDim, '', '1', 'N' );
DimensionElementInsert( vDim, '', '2', 'N' );
DimensionElementInsert( vDim, '', '3', 'N' );
DimensionElementInsert( vDim, '', 'South America', 'C' );
DimensionElementInsert( vDim, '', '4', 'N' );
DimensionElementInsert( vDim, '', '5', 'N' );
DimensionElementInsert( vDim, '', '6', 'N' );
DimensionElementInsert( vDim, '', '7', 'N' );
DimensionElementInsert( vDim, '', 'Europe', 'C' );
DimensionElementInsert( vDim, '', 'Benelux', 'C' );
DimensionElementInsert( vDim, '', '11', 'N' );
DimensionElementInsert( vDim, '', '12', 'N' );
DimensionElementInsert( vDim, '', '13', 'N' );
DimensionElementInsert( vDim, '', 'Central Europe', 'C' );
DimensionElementInsert( vDim, '', '16', 'N' );
DimensionElementInsert( vDim, '', '17', 'N' );
DimensionElementInsert( vDim, '', 'Iberia', 'C' );
DimensionElementInsert( vDim, '', '18', 'N' );
DimensionElementInsert( vDim, '', '19', 'N' );
DimensionElementInsert( vDim, '', 'Islands', 'C' );
DimensionElementInsert( vDim, '', '14', 'N' );
DimensionElementInsert( vDim, '', '15', 'N' );
DimensionElementInsert( vDim, '', 'Scandinavia', 'C' );
DimensionElementInsert( vDim, '', '10', 'N' );
DimensionElementInsert( vDim, '', '8', 'N' );
DimensionElementInsert( vDim, '', '9', 'N' );
DimensionElementInsert( vDim, '', 'Southern Europe', 'C' );
DimensionElementInsert( vDim, '', '20', 'N' );
DimensionElementInsert( vDim, '', '21', 'N' );
DimensionElementComponentAdd( vDim, 'World', 'Americas', 1 );
DimensionElementComponentAdd( vDim, 'Americas', 'North America', 1 );
DimensionElementComponentAdd( vDim, 'North America', '1', 1 );
DimensionElementComponentAdd( vDim, 'North America', '2', 1 );
DimensionElementComponentAdd( vDim, 'North America', '3', 1 );
DimensionElementComponentAdd( vDim, 'Americas', 'South America', 1 );
DimensionElementComponentAdd( vDim, 'South America', '4', 1 );
DimensionElementComponentAdd( vDim, 'South America', '5', 1 );
DimensionElementComponentAdd( vDim, 'South America', '6', 1 );
DimensionElementComponentAdd( vDim, 'South America', '7', 1 );
DimensionElementComponentAdd( vDim, 'World', 'Europe', 1 );
DimensionElementComponentAdd( vDim, 'Europe', 'Benelux', 1 );
DimensionElementComponentAdd( vDim, 'Benelux', '11', 1 );
DimensionElementComponentAdd( vDim, 'Benelux', '12', 1 );
DimensionElementComponentAdd( vDim, 'Benelux', '13', 1 );
DimensionElementComponentAdd( vDim, 'Europe', 'Central Europe', 1 );
DimensionElementComponentAdd( vDim, 'Central Europe', '16', 1 );
DimensionElementComponentAdd( vDim, 'Central Europe', '17', 1 );
DimensionElementComponentAdd( vDim, 'Europe', 'Iberia', 1 );
DimensionElementComponentAdd( vDim, 'Iberia', '18', 1 );
DimensionElementComponentAdd( vDim, 'Central Europe', '19', 1 );
DimensionElementComponentAdd( vDim, 'Iberia', '19', 1 );
DimensionElementComponentAdd( vDim, 'Europe', 'Islands', 1 );
DimensionElementComponentAdd( vDim, 'Islands', '14', 1 );
DimensionElementComponentAdd( vDim, 'Islands', '15', 1 );
DimensionElementComponentAdd( vDim, 'Europe', 'Scandinavia', 1 );
DimensionElementComponentAdd( vDim, 'Scandinavia', '10', 1 );
DimensionElementComponentAdd( vDim, 'Scandinavia', '8', 1 );
DimensionElementComponentAdd( vDim, 'Scandinavia', '9', 1 );
DimensionElementComponentAdd( vDim, 'Europe', 'Southern Europe', 1 );
DimensionElementComponentAdd( vDim, 'Southern Europe', '20', 1 );
DimensionElementComponentAdd( vDim, 'Southern Europe', '21', 1 );
# Dimension: Msr
vDim = vDim3;
EndIf;
DimensionElementInsert( vDim, '', 'T', 'C' );
DimensionElementInsert( vDim, '', 'P', 'N' );
DimensionElementInsert( vDim, '', 'Q', 'N' );
DimensionElementComponentAdd( vDim, 'T', 'P', 2 );
DimensionElementComponentAdd( vDim, 'T', 'Q', 1 );
# Dimension: }Hold
vDim = '}Hold';
EndIf;
DimensionElementInsert( vDim, '', 'HoldStatus', 'S' );
# Cube creation
CubeCreate( vCube
  , vDim1
  , vDim2
  , vDim3
A new custom TI process was proposed by myself to Bedrock TM1. It was approved:
https://github.com/cubewise-code/bedrock/pull/378
The process allows to create a holds cube, destroy a holds cube, release all holds, export all holds, import all holds.
This can be done for a selection of cubes, and clients and groups.
All feedback welcome.
