Colum and line charts question - PAW - Multi line
mrdauduong
Version: PA 2.0.74.23
Excel Version: Excel 2016
Post by mrdauduong »
hi,
hope everyone well, i have a small question about colum and line charts PAW
is there anyway to have 2 more line? (right now, i can have only 1 line in field, when i try to insert another, it is not work)
i want 1 line for other cost, 1 line for interne cost and 1 line for externe cost.
thank a lot of your help ! :idea:
Cross-posted in IBM Community
https://community.ibm.com/community/use ... 4eda43146b
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: Colum and line charts question - PAW - Multi line
Post by Elessar »
You need "Color" section in "Fields" tab for this.
Image 4.png (16.99 KiB) Viewed 2678 times
mrdauduong
Elessar wrote: Mon Oct 03, 2022 3:08 pm Hi,
thanks you for your reponse. it work well with "line" charts
but when iam in "colum and line" charts, i can only put 1 line in this field (photo before change and photo after change)
thank
colum and line chart question - after change.PNG (57.16 KiB) Viewed 2675 times
colum and line chart question - before change.png (50.62 KiB) Viewed 2675 times
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
You should use the "couleur" fields. One of them is for columns, one is for lines (my French is too bad)
Image 4.png (53.21 KiB) Viewed 2650 times
mrdauduong
thank Elessar the for the fast repose.
Can you show me what you put in the "couleur" fields?
My probleme is my colum and my line came from the same dimension FG_account
with colum is total account and line is the detail of account
i can not do something to make it work.
thank a lot for your help!
Elessar wrote: Wed Oct 05, 2022 6:41 am You should use the "couleur" fields. One of them is for columns, one is for lines (my French is too bad)
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
I've dragged random dimensions (Version and Cost center) to colors just to show how it works.
This depends on what you want to be split to different lines and different columns. Note that This should be different dimensions
