Stargate View is Not Caching
AliUgur
Version: TM1 10.2.2
Excel Version: Excel 2013
Post by AliUgur »
I tried to use Stargate View for a large cube for the first time but couldn't create it. I debugged it also from tm1s-log.properties and I am getting information about it like at the bottom:
After a new stargate is created, it destroys it a couple of minutes later. Also, I am not able to see information like the Number of Stored Views or Memory Used For Views in the }StatsbyCube cube.
As I check from the link: https://everanalytics.wordpress.com/201 ... _deepdive/
I need to see "ViewStorage::AddStargate: Stargate (Some_Memory_Address) added to ViewStorage (Memory_Address)" this information if my view is set as Stargate View but I couldn't see it in the log files.
Any help would be greatly appreciated.
Re: Stargate View is Not Caching
What version of PA are you running? I had issues previously.
What VMM and VMT settings have you allocated to the cube?
BR, George.
AliUgur
Version: TM1 10.2.2
Post by AliUgur »
Hi gtonkin,
Thanks for your reply.
PLANANALYTICS_version=PLANANALYTICS-AW64-ML-RTM-10.2.5200.234-0.
And I put VMT as 0 to create the Stargate view and VMM as 30000000000. Also, I tried the lower VMMs (5 GB, 10 GB, etc.). But, I was getting the same information as destroying the Stargate view. I will fix the VMM value after I create the stargate view but for now, I put the highest VMM as much as I can.
These are the values I got when I start the Performance Monitor.
If VMT = 0 then the default value will be used which I believe is 5 seconds. So if the view construct takes less than 5 seconds then nothing will be cached.
AliUgur
Version: TM1 10.2.2
Post by AliUgur »
Hi lotsaram,
thanks for your reply.
I set the VMT 2 or 3 before and had the same issue. The view that I try to cache as Stargate View is opening around 15-20 seconds.
I tried many things to set VMT and VMM but couldn't create a stargate view.
Just looking at your TM1 version, looks like you are on 10.2.2 base - IIRC, this was awful and FP4 fixed many, many issues.
If you cannot test on a current version like PA 2.0.9.14 then suggest you try upgrade to 10.2.2 FP4 to see if this resolves.
BR, George.
AliUgur
Version: TM1 10.2.2
Post by AliUgur »
Hi gtonkin,
I tried to create Stargate View on my local computer on the Planing Sample instance which is an IBM sample database. I had the same error.
My Pa version is 11.8.100.13
I used the "plan_BudgetPlan" cube and created a view with all elements from all dimensions which is opening around 7 seconds.
As a VMT and VMM settings, I gave VMT as 1 second and VMM as 1GB to see if it will create StargateView. But, I had the same error.
Maybe, I am missing a point to set up for creating Stargate View but I couldn't find any other information about it.
Thanks for the help.
A couple more things to check:
  • Could you share your TM1S.cfg, could be something in there that needs tweaking - do not need to see server names, data dirs etc. MTQ is critical. Also need to look for entries like MTQ.SingleCellConsolidation=false, MTQ.CTreeWorkUnitMerge, MTQ.MultithreadStargateCreationUsesMerge etc.
  • Are you opening the view via the cube viewer, not running a TI?
  • Was the view created manually or via TI? If TI, did you use ViewConstruct?
  • VMM of 1 may be too short - >3 is probably more suitable - have you tried slightly higher values again in PA?
  • Have you tried switching dimensions around between Context, Rows and Columns to see if there is a difference?
  • Is the view only Leaf elements, only C levels or a mixture?
Cannot think of more right now but maybe with the above and your feedback other members can offer further advice.
BR, George.
AliUgur
Version: TM1 10.2.2
Post by AliUgur »
Hi gtonkin,
Thanks for your help and the questions.
I started to use and understand Stargateview on a simple database. So, I used the IBM Planning Samples instance and on my local PA(11.8.100.13) I created a view(manually) that uses plan_BudgetPlan cube (Planning Samples database). I opened all the dimension items(C and N levels) and the view opens around 7-8 seconds.
To answer your questions;
I didn't use MTQ parameters to create a Stargate View. Should I use them? (I didn't see it on the documentation of IBM and the forums.)
Additionally, I created the view manually and opened it from the cube viewer. By the way, I used the ViewConstruct function also but didn't work in my case. I tried different VMT settings like 3,4,5 etc.
Lastly, I changed the dimension places as like I set a dimension as a title dimension, but nothing changed.
If I can create it on this instance then I will try it for my big cube.
Tm1s file:
ServerLogging=F
SecurityPackageName=Kerberos
IntegratedSecurityMode=1
UseSSL=T
ServerName=Planning Sample
DataBaseDirectory=.
AdminHost=
PortNumber=12345
HTTPPortNumber=12354
ClientMessagePortNumber=
Savetime=
Downtime=
LicenseMetricTime=
ProgressMessage=True
AuditLogOn=F
AuditLogMaxFileSize= 100 MB
AuditLogUpdateInterval=60
PersistentFeeders=F
ParallelInteraction=T
IPVersion=ipv4
ServerCAMIPVersion=ipv4
EnableNewHierarchyCreation=T
EnableTIDebugging=T
PerformanceMonitorOn=T
UseStargateForRules=F (I added this parameter at the end to see if it will have an effect, but I tried everything before this parameter also.)
As a start try add MTQ to the TM1s.cfg:
MTQ=ALL
This article may also help:
https://www.ibm.com/support/pages/tip-a ... cognos-tm1
BR, George.
