Hi, all
Just found an interesting issue, when a cell is definitely underfed (no feeder attaching to it and not showing in 0 suppression and can't be exported with 0 suppression), the check feeders showing nothing for it and I am expecting "No Fed" value for it but showing blank.
Tried unloading, deleting all persistent feeders and rebooting but no luck. Could it be a bug in this version? Thanks.
check feeders not working properly in PAL 2.0.9.4
burnstripe
- Version: 2.0.9
Re: check feeders not working properly in PAL 2.0.9.4
Is there are blb file (cube_name.blb) existing when the service isn't running. If so try deleting that as well as the feeder file. And see if that remedies...
- macsir
- Version: PAL 2.0.9
Thanks, mate. Deleted all blb files and reprocessed all feeders files after rebooting but no avail.burnstripe wrote: ↑Sun Apr 03, 2022 5:54 am Is there are blb file (cube_name.blb) existing when the service isn't running. If so try deleting that as well as the feeder file. And see if that remedies...
- PavoGa
- Excel Version: 2013 PAW
For what it is worth, I have seen this problem as well. Pain in the rear end, but no solution to offer.
Ty
Cleveland, TN
Cleveland, TN
I concur. I can't remember exactly when check feeders stopped working (we're on the IBM Cloud) but it's been at least a year. Luckily, it's pretty easy to tell when a cell is not fed so it isn't that big of a deal.
- macsir
Thanks, guys. I will check it again after upgrading into a newer version.
