check feeders not working properly in PAL 2.0.9.4
macsir
Version: PAL 2.0.9
Post by macsir »
Hi, all
Just found an interesting issue, when a cell is definitely underfed (no feeder attaching to it and not showing in 0 suppression and can't be exported with 0 suppression), the check feeders showing nothing for it and I am expecting "No Fed" value for it but showing blank.
Tried unloading, deleting all persistent feeders and rebooting but no luck. Could it be a bug in this version? Thanks.
burnstripe
Version: 2.0.9
Re: check feeders not working properly in PAL 2.0.9.4
Post by burnstripe »
Is there are blb file (cube_name.blb) existing when the service isn't running. If so try deleting that as well as the feeder file. And see if that remedies...
macsir
Version: PAL 2.0.9
Post by macsir »
burnstripe wrote: Sun Apr 03, 2022 5:54 am Is there are blb file (cube_name.blb) existing when the service isn't running. If so try deleting that as well as the feeder file. And see if that remedies...
Thanks, mate. Deleted all blb files and reprocessed all feeders files after rebooting but no avail. :(
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
For what it is worth, I have seen this problem as well. Pain in the rear end, but no solution to offer.
Ty
Cleveland, TN
I concur. I can't remember exactly when check feeders stopped working (we're on the IBM Cloud) but it's been at least a year. Luckily, it's pretty easy to tell when a cell is not fed so it isn't that big of a deal.
macsir
Version: PAL 2.0.9
Post by macsir »
Thanks, guys. I will check it again after upgrading into a newer version. :)
