TM1 Cube Size
pooja11284
OLAP Product: cognos
Version: 9.5
TM1 Cube Size
Post by pooja11284 »
Where do we get information about the size of Cube on the TM1 Server
Re: TM1 Cube Size
Post by David Usherwood »
Many ways:
Select the Cubes item. The RAM footprint of the cube is over on the right. You can click on the column heading to sort.
Run Performance Monitor, and look at }StatsbyCube. This gives you more detail about what is using the RAM ie input data, feeders, etc.
To find the disc footprint of the cube, look in the server directory - maybe I'm being a bit too obvious here :) .
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: TM1 Cube Size
Post by rkaif »
In the Server Explorer, Click on the Cubes and then in the Properties Window it will tell you the size of the cubes.
See the attached screenshot
Cube Size
Cube Size
Cheers!
Rizwan Kaif
jim wood
Version: PA 2.0.7
Re: TM1 Cube Size
Post by jim wood »
As far as I am aware that is the size upon load. It doesn't tell you the actual cube size including cache and updates,
wilsonric
Version: 2.0.9
Excel Version: 365 MSO 16-0-13127
Re: TM1 Cube Size
Post by wilsonric »
We have found this list also includes cubes that are flagged to load on demand.
So they should not be consuming any RAM? Or at least very little?
Richard
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Re: TM1 Cube Size
Post by Adam »
wilsonric wrote: Tue Feb 09, 2021 5:26 am We have found this list also includes cubes that are flagged to load on demand.
I think any detailed analysis on RAM, as you suggest, should be done using performance monitor. It will give you quite granular breakdown. ROT is that TM1, to date, does not give back any memory once it takes it from the OS.
Take care,
Adam
