I'm trying to set ODBC connection to xlsx.
I get no results (there are in the Excel) just blank column F1
Roei
ODBC connection to EXCEL
- roei61
- OLAP Product: PAX
- Version: 2.0.7
- 1.PNG (14.04 KiB) Viewed 4550 times
Re: ODBC connection to EXCEL
Do you have the 64-bit ODBC driver for Excel installed on the TM1 server?
- roei61
- OLAP Product: PAX
- Version: 2.0.7
My Excel in the server is 32Bit and I cannot change the installation.
I don't think I'll be able to install 62bit ODBC driver if my Excel is 32
Then you won't be able to do what you asked about.
Perhaps look at this?
https://code.cubewise.com/odbc-connect
Also, I recall this from earlier releases. Can't say whether it survived in TM1 11/PA:
https://www.ibm.com/support/knowledgece ... proxy.html
