TM1 10.2.2 Turbo Intergrator unable to connect Amazon Redshift
thush_CMB
Version: 10.2.2 FP5
Excel Version: 2010 32bit
Post by thush_CMB »
Currently, I have an issue where TI unable to open ODBC connection to Amazon Redshift. This connection also worked well initially and unable connect now. (image 1).
Driver used is Amazon Redshift (x64) (image 3).
However, connection test is successful on Windows ODBC Data Source Administrator (image 2). ALl other ODBC connections work well with TM1.
Image 1
Image 1
Image 3
Image 3
Image 2
Image 2
Has anyone successfully connected Amazon Redshift to TM1? also, any idea what is causing this?
Appreciate any help.
macsir
Version: PAL 2.0.9
Re: TM1 10.2.2 Turbo Intergrator unable to connect Amazon Redshift
Post by macsir »
Are you sure your password in TI is right?
thush_CMB
Version: 10.2.2 FP5
Post by thush_CMB »
Yes, the password is correct. The process ran for last 5 days successfully and now it cannot connect.
It has the same login details as 'ODBC data source Administrator'.
blackhawk
Post by blackhawk »
Thush_CMB:
You say it ran successfully previously?
Perhaps an application-based security/firewall change on the server?
Is the TM1 Service tied to a network account? Could that network account password have been changed but TM1 instance was never cycled to re-load it's authentication? i.e. Lost its ability to use domain services?
...Just a few thoughts.....
mincharug.shulft
OLAP Product: Applix,Cognos TM!
Version: applix9.0Cognos tm1 9.5.1
Excel Version: Excel 2010 2007
Post by mincharug.shulft »
Hi All:
I have requirement: I have the data in Amazon AWS S3 and i need to read the Data using TI (Tm1 10.2.2 on-prem Enviroment) and load into Cube. Is there any solution to achieve this? really appreciated any solution?
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
mincharug.shulft wrote: ↑Thu Jan 23, 2020 9:04 pm Hi All:
You have two different post with the same content mate. Already replied to the other one.
Evgeny
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
blackhawk wrote: ↑Fri Feb 23, 2018 7:03 pm Thush_CMB:
As far as I remember access to AWS RS resources are controlled by IAM. Perhaps check whether data_analyst is assigned to a correct IAM role(s).
Evgeny
