Hello friends,
i'm searching for a .NET Wrapper for the TM1 API (or is there a better way), i want to create some programs around TM1 but i really can't find any actual things at google.
Maybe some user here have something to share?
Thanks and BR
HighKeys
c# and Tm1
Re: c# and Tm1
There is a better way. It's called the REST API. You would be crazy to create programs around a dying API, which the legacy TM1 API definitely is. It's only a matter of time before they pull the plug on it. They would have done it already if it weren't for everyone's dependency on Architect. Once PAW get's better at admin/developer functions they'll pull Architect and once that's gone there is no need for the legacy API.
HighKeys
- OLAP Product: TM1 / TM1 Web / Perspectives
- Version: Planning Analytics V2.0.9
Re: c# and Tm1
Hello tomok!
i thought the c++ api is still active in development, i tried to activate the Web API (it works when i get the metadata but i cant list cubes or something..)
Is there any good documentation on this? (WEB APi, c++ Api etc) or do you know this just from experience? Its hard to find good information about the API stuff.
Thanks for your help!
Re: c# and Tm1
It most definitely isn't and hasn't been updated in quite a few years. The only reason it is still a part of Planning Analytics is because Architect and Perspectives are built on top of it. Perspectives already has a replacement in PAFE. Architect has a replacement in PAW but it isn't there yet in my opinion (and a lot of others too). IBM is dying to kill it. Once they do the C++ API will be killed.
You can Google it just as easily as I can.
Re: c# and Tm1
Any TM1 API other than the Ressful API is dead. Simple as that.HighKeys wrote: ↑Wed Nov 20, 2019 10:04 am Hello tomok!
Ricky Marwan
- Version: 9.4
Re: c# and Tm1
Here is a quick and dirty console app to convert slice to snapshot.
What you need:
RestSharp
EPPlus
What you need:
RestSharp
EPPlus
using System;
using System.IO;
using OfficeOpenXml;
using System.Collections.Generic;
using RestSharp;
using RestSharp.Authenticators;
using System.Text.RegularExpressions;
namespace ConsoleApp1
public class Cell
public double Value { get; set; }
public class Attributes
public string Caption { get; set; }
public class Value
public string Name { get; set; }
public string UniqueName { get; set; }
public string AllLeavesHierarchyName { get; set; }
public Attributes Attributes { get; set; }
public class RootObject
public string ID { get; set; }
public List<Cell> Cells { get; set; }
public List<Value> value { get; set; }
public class TM1Session
public string Value { get; set; }
class Program
static void ReportBurst(string apiurl, string username, string password, string template, string output)
var client = new RestClient(apiurl);
client.Authenticator = new HttpBasicAuthenticator(username, password);
var request = new RestRequest("api/v1/Configuration");
var response = client.Get(request);
if (response.Cookies.Count == 0)
throw new Exception("Invalid username or password");
var cookies = response.Cookies;
string sessionId = cookies[0].Value;
Regex regex = new Regex("SUBNM|VIEW");
FileInfo existingFile = new FileInfo(template);
FileInfo outputFile = new FileInfo(output);
using (var package = new ExcelPackage(existingFile))
foreach (ExcelWorksheet worksheet in package.Workbook.Worksheets)
var lastRow = worksheet.Dimension.End.Row;
var lastColumn = worksheet.Dimension.End.Column;
for (int r = 1; r <= lastRow; r++)
for (int c = 1; c <= lastColumn; c++)
ExcelRange cell = worksheet.Cells[r, c];
if (cell != null)
string formula = cell.Formula;
if (formula.Contains("DBRW"))
string[] dbrw = ParseDBRW(formula);
string servercube = worksheet.Cells[dbrw[0]].Value.ToString();
string server = servercube.Split(':')[0];
string cube = servercube.Split(':')[1];
string[] elements = new string[dbrw.Length - 1];
for (int e = 1; e < dbrw.Length; e++)
string element = worksheet.Cells[dbrw[e]].Value.ToString();
elements[e - 1] = element;
var dimensions = GetDimensions(client, sessionId, cube);
double newValue = GetCubeValue(client, sessionId, cube, dimensions, elements);
cell.Value = newValue;
if (regex.IsMatch(formula))
cell.Value = cell.Value;
package.SaveAs(outputFile);
var logout = new RestRequest("api/logout");
logout.AddCookie("TM1SessionId", sessionId);
client.Get(logout);
static void Main(string[] args)
try
if (args.Length < 5)
throw new Exception("Invalid arguments. example: \"http://host:port/\" \"admin\" \"apple\" \"C:\\Temp\\Template.xlsx\" \"C:\\Temp\\Output.xlsx\" ");
//Console.Read();
Console.WriteLine(args[0] + " " + args[1] + " " + args[2] + " " + args[3] + " " + args[4]);
ReportBurst(args[0], args[1], args[2], args[3], args[4]);
Console.WriteLine("Done");
catch(Exception ex)
Console.WriteLine(ex.Message);
public static double GetCubeValue(RestClient client, string sessionId, string cube, List<Value> dimensions, string[] dbrw)
var request = new RestRequest("api/v1/ExecuteMDX");
request.AddHeader("Content-Type", "application/json");
request.AddQueryParameter("$expand", "Cells($select=Value)");
request.AddCookie("TM1SessionId", sessionId);
var sBody = BuildMDX(cube, dimensions, dbrw);
request.AddJsonBody(sBody);
var response = client.Post<RootObject>(request);
return response.Data.Cells[0].Value;
public static List<Value> GetDimensions(RestClient client, string sessionId, string cube)
var request = new RestRequest("api/v1/Cubes('" + cube+"')/Dimensions");
request.AddHeader("Accept", "application/json;odata.metadata=none");
var response = client.Get<RootObject>(request);
var content = response.Content;
return response.Data.value;
public static string BuildMDX(string cube, List<Value> dimensions, string[] dbrw)
string mdx = "{\"MDX\":\"SELECT{(";
for (int i=0;i<dimensions.Count;i++)
mdx = mdx + "[" + dimensions[i].Name + "].[" + dbrw[i] + "],";
mdx = mdx.Substring(0, mdx.Length - 1);
mdx = mdx + ")} on 0 FROM ["+cube+"]\"}";
return mdx;
static string[] ParseDBRW(string formula)
List<string> list = new List<string>();
string strStart = "(";
int startIndex = formula.IndexOf(strStart) + 1;
int endIndex = formula.IndexOf(")", startIndex);
string str = formula.Substring(startIndex, endIndex - startIndex);
return str.Split(',');
Ricky Marwan
