c# and Tm1
HighKeys
OLAP Product: TM1 / TM1 Web / Perspectives
Version: Planning Analytics V2.0.9
c# and Tm1
Post by HighKeys »
Hello friends,
i'm searching for a .NET Wrapper for the TM1 API (or is there a better way), i want to create some programs around TM1 but i really can't find any actual things at google.
Maybe some user here have something to share?
Thanks and BR
HighKeys
Re: c# and Tm1
HighKeys wrote: Mon Nov 18, 2019 12:31 pm i'm searching for a .NET Wrapper for the TM1 API (or is there a better way), i want to create some programs around TM1 but i really can't find any actual things at google.
There is a better way. It's called the REST API. You would be crazy to create programs around a dying API, which the legacy TM1 API definitely is. It's only a matter of time before they pull the plug on it. They would have done it already if it weren't for everyone's dependency on Architect. Once PAW get's better at admin/developer functions they'll pull Architect and once that's gone there is no need for the legacy API.
HighKeys
Re: c# and Tm1
Post by HighKeys »
Hello tomok!
i thought the c++ api is still active in development, i tried to activate the Web API (it works when i get the metadata but i cant list cubes or something..)
Is there any good documentation on this? (WEB APi, c++ Api etc) or do you know this just from experience? Its hard to find good information about the API stuff.
Thanks for your help!
Re: c# and Tm1
HighKeys wrote: Wed Nov 20, 2019 10:04 am i thought the c++ api is still active in development
It most definitely isn't and hasn't been updated in quite a few years. The only reason it is still a part of Planning Analytics is because Architect and Perspectives are built on top of it. Perspectives already has a replacement in PAFE. Architect has a replacement in PAW but it isn't there yet in my opinion (and a lot of others too). IBM is dying to kill it. Once they do the C++ API will be killed.
HighKeys wrote: Wed Nov 20, 2019 10:04 am Is there any good documentation on this? (WEB APi, c++ Api etc)
You can Google it just as easily as I can.
Re: c# and Tm1
HighKeys wrote: Wed Nov 20, 2019 10:04 am Hello tomok!
Any TM1 API other than the Ressful API is dead. Simple as that.
Ricky Marwan
Version: 9.4
Re: c# and Tm1
Post by Ricky Marwan »
Here is a quick and dirty console app to convert slice to snapshot.
What you need:
RestSharp
EPPlus
using System;
using System.IO;
using OfficeOpenXml;
using System.Collections.Generic;
using RestSharp;
using RestSharp.Authenticators;
using System.Text.RegularExpressions;
namespace ConsoleApp1
    public class Cell
        public double Value { get; set; }
    public class Attributes
        public string Caption { get; set; }
    public class Value
        public string Name { get; set; }
        public string UniqueName { get; set; }
        public string AllLeavesHierarchyName { get; set; }
        public Attributes Attributes { get; set; }
    public class RootObject
        public string ID { get; set; }
        public List<Cell> Cells { get; set; }
        public List<Value> value { get; set; }
    public class TM1Session
        public string Value { get; set; }
    class Program
        static void ReportBurst(string apiurl, string username, string password, string template, string output)
            var client = new RestClient(apiurl);
            client.Authenticator = new HttpBasicAuthenticator(username, password);
            var request = new RestRequest("api/v1/Configuration");
            var response = client.Get(request);
            if (response.Cookies.Count == 0)
                throw new Exception("Invalid username or password");
            var cookies = response.Cookies;
            string sessionId = cookies[0].Value;
            Regex regex = new Regex("SUBNM|VIEW");
            FileInfo existingFile = new FileInfo(template);
            FileInfo outputFile = new FileInfo(output);
            using (var package = new ExcelPackage(existingFile))
                foreach (ExcelWorksheet worksheet in package.Workbook.Worksheets)
                    var lastRow = worksheet.Dimension.End.Row;
                    var lastColumn = worksheet.Dimension.End.Column;
                    for (int r = 1; r <= lastRow; r++)
                        for (int c = 1; c <= lastColumn; c++)
                            ExcelRange cell = worksheet.Cells[r, c];
                            if (cell != null)
                                string formula = cell.Formula;
                                if (formula.Contains("DBRW"))
                                    string[] dbrw = ParseDBRW(formula);
                                    string servercube = worksheet.Cells[dbrw[0]].Value.ToString();
                                    string server = servercube.Split(':')[0];
                                    string cube = servercube.Split(':')[1];
                                    string[] elements = new string[dbrw.Length - 1];
                                    for (int e = 1; e < dbrw.Length; e++)
                                        string element = worksheet.Cells[dbrw[e]].Value.ToString();
                                        elements[e - 1] = element;
                                    var dimensions = GetDimensions(client, sessionId, cube);
                                    double newValue = GetCubeValue(client, sessionId, cube, dimensions, elements);
                                    cell.Value = newValue;
                                if (regex.IsMatch(formula))
                                    cell.Value = cell.Value;
                        package.SaveAs(outputFile);
            var logout = new RestRequest("api/logout");
            logout.AddCookie("TM1SessionId", sessionId);
            client.Get(logout);
        static void Main(string[] args)
            try
                if (args.Length < 5)
                    throw new Exception("Invalid arguments. example: \"http://host:port/\" \"admin\" \"apple\" \"C:\\Temp\\Template.xlsx\" \"C:\\Temp\\Output.xlsx\" ");
                    //Console.Read();
                Console.WriteLine(args[0] + " " + args[1] + " " + args[2] + " " + args[3] + " " + args[4]);
                ReportBurst(args[0], args[1], args[2], args[3], args[4]);
                Console.WriteLine("Done");
            catch(Exception ex)
                Console.WriteLine(ex.Message);
        public static double GetCubeValue(RestClient client, string sessionId, string cube, List<Value> dimensions, string[] dbrw)
            var request = new RestRequest("api/v1/ExecuteMDX");
            request.AddHeader("Content-Type", "application/json");
            request.AddQueryParameter("$expand", "Cells($select=Value)");
            request.AddCookie("TM1SessionId", sessionId);
            var sBody = BuildMDX(cube, dimensions, dbrw);
            request.AddJsonBody(sBody);
            var response = client.Post<RootObject>(request);
            return response.Data.Cells[0].Value;
        public static List<Value> GetDimensions(RestClient client, string sessionId, string cube)
            var request = new RestRequest("api/v1/Cubes('" + cube+"')/Dimensions");
            request.AddHeader("Accept", "application/json;odata.metadata=none");
            var response = client.Get<RootObject>(request);
            var content = response.Content;
            return response.Data.value;
        public static string BuildMDX(string cube, List<Value> dimensions, string[] dbrw)
            string mdx = "{\"MDX\":\"SELECT{(";
            for (int i=0;i<dimensions.Count;i++)
                mdx = mdx + "[" + dimensions[i].Name + "].[" + dbrw[i] + "],";
            mdx = mdx.Substring(0, mdx.Length - 1);
            mdx = mdx + ")} on 0 FROM ["+cube+"]\"}";
            return mdx;
        static string[] ParseDBRW(string formula)
            List<string> list = new List<string>();
            string strStart = "(";
            int startIndex = formula.IndexOf(strStart) + 1;
            int endIndex = formula.IndexOf(")", startIndex);
            string str = formula.Substring(startIndex, endIndex - startIndex);
            return str.Split(',');
Ricky Marwan
