I'm trying to export a bunch of CSV reports involving one TI process running another. The TI being called does work - I tested it on its own, but the calling procedure doesn't - no report is saved in the folder I assigned.
TI 1 calls TI 2
TI1 data source is a CSV file with 2 columns, first column has a list of names (these are the people who will receive a report and the reports will be named as lyn.CSV; Tom.CSV; Mike.CSV...), column 2 has years as string like 2019, 2020, 2021...(these are consolidated elements in the "SM_Financial_Time" dimension.
Name Year
lyn 2018
Tom 2019
mike 2020
the only code I have in TI1 is under data:
ExecuteProcess('SampleExport', 'pExportName', Name, 'pName', Name, 'pYear', Yr);
TI 2 (SampleExport) is the TI being called.
I have the sections of codes attached.
The view did get updated with subsets "lyn", "Tom", "mike" created in the SM_Financial_Time dimension.
Can someone please help me understand why the CSV files aren't generating? the log says
"Lyn", "2018", Data Source line (2) error: Data procedure line (5): erros occured during execution of process "SampleExport"
thanks!
ExecuteProcess not working
lynnsong986
- Data.PNG (16.73 KiB) Viewed 5908 times
- Prolog.PNG (20.31 KiB) Viewed 5908 times
- Para.PNG (12.04 KiB) Viewed 5908 times
ascheevel
- Version: PA 2.0.9.1
- Excel Version: 365
Re: ExecuteProcess not working
Did the execution of SampleExport when called by your 1st TI generate a separate log file of the errors it encountered?
MarenC
- Excel Version: Excel 2016
Your data source is a cube view and if this includes consolidations, you will need to ensure it doesn't skip consolidated values.
see ViewExtractSkipCalcsSet
Maren
Maren
lynnsong986
No I don't think so, it actually worked when I only have a list of names in the CSV name, it generated the CSV reports in the path with the names. but it didn't generate any file after I played around and added the Yr in the CSV.Did the execution of SampleExport when called by your 1st TI generate a separate log file of the errors it encountered?
I have the skip consolidated unchecked, the problem is that no file is exported at all...Your data source is a cube view and if this includes consolidations, you will need to ensure it doesn't skip consolidated values.
thanks both for your help!
lynnsong986
Here is the error messages...
- log.PNG (12.9 KiB) Viewed 5887 times
ascheevel
You're in the process error messages for your calling process. In the server log, you should see individual ERROR entries for each of those process calls, you can then double-click on one of those to see the details. Alternatively, you can navigate to the folder where your log files are, sort by date modified, and look for any files with your 2nd TI process name in the file name. The process error log file will look something like "TM1ProcessError_20191106....SampleExport.log".
You mentioned in a different thread that there is a "tm1 mastermind" at your company. Have you checked with them? They may be able to provide faster/better help.
lynnsong986
The problem is that we work at different work stations and he's super busy...I'll try to find the log files and go from there. Thanks so much!
