At Wits' End: "File not found: tm1xl.ocx"
image2x
- OLAP Product: TM1, PAX, PAW, SPSS
- Version: 2.0.916.10 on RHEL
After finally conceding (based on researching prior posts) that the only reliable way to install TM1 Perspectives was to do so with Administrator rights, I had our package people build and install Perspectives with administrator privileges.
Apparently, it’s a known issue that TM1 must register some .dll and .ocx files during installation and these will fail without admin privileges. Before trying Perspectives after it was administratively installed, I was encouraged to see that indeed the following objects were successfully registered:
C:\Program Files\Cognos\TM1\bin\tm1prc.dll
C:\Program Files\Cognos\TM1\bin\tm1xl.ocx
C:\Program Files\Cognos\TM1\bin\TM1RuleEditor.dll
C:\Program Files\Cognos\TM1\bin\ExcelServiceCom.dll
Unfortunately, the result was the same with a “Run-time error: 53: File not found: tm1xl.ocx†Excel error when launching Perspectives.
See the attached .xls file for more specifics on the registration properties of these files.
The package installed MR1_X32 first and then FP002_X32. I'm running Excel 2007. I've got a week to figure this out before we're supposed to deploy to numerous end users.
Thoughts? Incantations???
Thanks. -- John
Thanks. -- John
- error.JPG (10.14 KiB) Viewed 25882 times
- tm1-registered-components.xls
- (19 KiB) Downloaded 1079 times
- paulsimon
- Version: PA 2.0.5
Re: At Wits' End: "File not found: tm1xl.ocx"
John
If you are still having problems, come back to me, but from memory I think that the file that you are missing is
tm1dasrv.dll
You need three files registered for the tm1xl.ocx to work (This is the In-Spreadsheet Browser by the way)
tm1dasrv.dll
tm1prc.dll
tm1xl.ocx
To register them, drag when on to regsvr32.exe in C:\Windows\System32.
You need local admin rights on the machine for this.
I am assuming that your machines are locked down so that only your IT Dept have local admin rights. The other alternative would be to ask them to login, uninstall TM1 and re-install it. As you have probably learnt by now, just about any bit of software will need local admin rights before it can be installed, so it is probably best to wait for the IT Dept to package the application properly, and make sure you test it before you sign off the package.
tm1dasrv.dll
tm1dasrv.dll
tm1prc.dll
tm1xl.ocx
image2x
Paul --
My install was in fact missing the tm1dasrv.dll binary altogether... I copied over the file from the server which has a functioning perspectives and registered it but got the same error message. Unfortunately, this was all the time I had today to work on this issue. It's still a front-burner problem though and it sounds like you may be on to something. Hopefully tomorrow the package guys will get around to trying an administrative install on a "virgin" laptop that hasn't already been subjected to multiple attempted perspective installations like mine has.
Anyhow, thanks again for your insights.
-- John
-- John
image2x
Thought I'd share the conclusion to three weeks of investigation...
The tm1xl.ocx error turns out to have been caused by a failure to load ssleay32.dll in the tm1p.xla VB code. There are several dll's that tm1p.xla tries to load before tm1xl.ocx. However, tm1p doesn't complain if any of these precursor dll's fail even though tm1xl.ocx is dependent upon them.
Ssleay32.dll is part of the open source OpenSSH package which Cognos is utilizing. Although this dll was properly installed, it appears to have been in conflict with some highly-privileged (system "owned" backed by a specialized group policy), custom (googling the .exe names returns nada), big brother monitoring package mandated by our IT group. This package also loads it's own ssleay32.dll. The fix was to replace TM1's bin/ssleay32.dll and bin/libeay32.dll with the dll's utilized by the monitoring package.
-- John
-- John
jyo
- OLAP Product: cognos
- Version: TM1 9.5.2
- Excel Version: excel 2003
Hi not able find any solution for this issue If tried to manually register tm1xl.ocx gettingb attached message
EM We know we are on a Win7 box if we find the following
if exist "C:\Program Files (x86)" goto :CHECKW7
REM Recreate the std XP directory if not found
if exist "C:\Program Files\Cognos At IBM" goto INSTALL
mkdir "C:\Program Files\Cognos At IBM"
if errorlevel=1 goto ERROR3
goto INSTALL
:INSTALL
REM copy HF6 and mapped worksheet - supress overwrite prompt, create all subdirs, copy sys/hidden as well
echo Installing TM1 version 9.5.2 HF6, please stand by...
xcopy /Y /E /I /H %TEMP%\952_HF6_x86_client\"*.*" "C:\Program Files\Cognos At IBM\TM1\" > NUL
if errorlevel=1 goto ERROR5
del "C:\Program Files\Cognos At IBM\TM1\install*.bat"
rem Only register if this is a non-msi install
if exist "C:\WINDOWS\Installer\{AD063608-666F-4B6F-B66E-204661EE9CB2}" goto SUCCESS
echo.
echo Registering Client Files...
echo.
REM Register Tm1prc.dll
Regsvr32 /s "C:\Program Files\Cognos At IBM\TM1\bin\Tm1prc.dll"
if errorlevel=1 goto ERROR4
REM Register Tm1xl.ocx
Regsvr32 /s "C:\Program Files\Cognos At IBM\TM1\bin\Tm1xl.ocx"
goto SUCCESS
:CHECKW7
REM Recreate the product directory if not found
if not exist "C:\Program Files (x86)\Cognos At IBM" goto INSTALLW7
mkdir "C:\Program Files (x86)\Cognos At IBM"
:INSTALLW7
xcopy /Y /E /I %TEMP%\952_HF6_x86_client\"*.*" "C:\Program Files (x86)\Cognos At IBM\TM1\" > NUL
del "C:\Program Files\Cognos At IBM (x86)\TM1\install*.bat"
echo.
echo.
Regsvr32 /s "C:\Program Files (x86)\Cognos At IBM\TM1\bin\Tm1prc.dll"
Regsvr32 /s "C:\Program Files (x86)\Cognos At IBM\TM1\bin\Tm1xl.ocx"
goto SUCCESS
:SUCCESS
echo.
echo Installation completed successfully.
echo.
pause
echo.
goto END
:ERROR1
echo.
echo * FAILED TO UNINSTALL PREVIOUS VERSION *
echo.
pause
echo.
goto END
:ERROR2
echo.
echo * FAILED TO REMOVE OLD COGNOS TM1 DIRECTORY *
echo.
pause
echo.
goto END
:ERROR3
echo.
echo * FAILED TO CREATE NEW COGNOS TM1 DIRECTORY *
echo.
pause
echo.
goto END
:ERROR4
echo.
echo * FAILED TO REGISTER CLIENT FILES *
echo.
pause
echo.
goto END
:ERROR5
echo.
echo * FAILED TO INSTALL COGNOS TM1 *
echo.
pause
echo.
goto END
:END
goto INSTALL
:INSTALL
echo.
echo.
goto SUCCESS
:CHECKW7
:INSTALLW7
echo.
echo.
goto SUCCESS
:SUCCESS
echo.
echo.
pause
echo.
goto END
:ERROR1
echo.
echo.
pause
echo.
goto END
:ERROR2
echo.
echo.
pause
echo.
goto END
:ERROR3
echo.
echo.
pause
echo.
goto END
:ERROR4
echo.
echo.
pause
echo.
goto END
:ERROR5
echo.
echo.
pause
echo.
goto END
:END
jyo
Please find error getting while trying to install 952_hf6_x86_client and error got tried to manually register tm1xl.ocx
- TM1 error.doc
- TM1 errors
- (42 KiB) Downloaded 1187 times
Are you aware that you don't actually "install" hot fixes? Hot fixes are loose file upgrades. You install the base version for the hot fix, in this case 9.5.2 x86. To install the hot fix all you do is ensure all TM1 components are stopped, copy the extracted contents of the hot fix folder into the bin directory then restart any services that were stopped.jyo wrote:Please find error getting while trying to install 952_hf6_x86_client and error got tried to manually register tm1xl.ocx
ithomas21
- OLAP Product: tm1
- Version: 9.5.1
- Excel Version: 2003
Check that you don't have another Visual C++ Redistributable installed. If you have the 2008 version installed it can conflict with the 2005 version
hansens
- Version: 9.5.2
- Excel Version: 2003-2007
Just as a follow-up and in case anyone else runs into this problem, at our company, we found that this issue was the result of an interaction with Cisco's CUPC (Cisco Unified Personal Communicator) software. From what I understand, when CUPC is installed, it puts hooks into some software packages to work with them. The hook into Excel caused our "Run-time error '53' File not found: tm1xl.ocx" problem. We instructed our I.T. department to uninstall CUPC and then reinstall it opting out of the hook into Excel. This resolved our problem. I can't say if this will work for everyone, but it worked for us.
Rtel
- Version: 10.2
- Excel Version: 2013
Hello, I am getting Tm1.ocx error 53.
I tried registering all the DLLs (tm1xl.ocx, tm1prc.dll,tm1dasrv.dll ) but still getting error. I checked the path of tm1.xla from VBA and its pointing to
C:\Program Files\ibm\cognos\tm1_64\bin64
I believe path to tm1p.xla should point to 'C:\Program Files\ibm\cognos\tm1_64\bin' folder since my MS Excel is 32 bit. If that's true, how do I change the TM1 perspective to look at 'C:\Program Files\ibm\cognos\tm1_64\bin64' folder for Tm1p.xla
Thnx
Rtel
Thnx
Rtel
Rtel
- Version: 10.2
Correction..
I believe path to tm1p.xla should point to 'C:\Program Files\ibm\cognos\tm1_64\bin' folder since my MS Excel is 32 bit. If that's true, how do I change the TM1 perspective to look at 'C:\Program Files\ibm\cognos\tm1_64\bin' folder for Tm1p.xla
You can point the shortcut to the correct file in the correct folder.
