TM1 Applications Rights saving error
nad_i
Post by nad_i »
I have a problem in Performance Modeler. I've created an application, deployed it, saved rights and it all worked well. Now I've tried to add another right and now I get an error: Rights saving error, [CCLMsg: system text:'Argument value is null'].
I've reseted tm1 server instance and application server, it didn't help.
Can anyone please help me?
Thanks in advance.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: TM1 Applications Rights saving error
Post by Elessar »
Check your tm1server.log. Are there any errors after you saved rights?
Also check this:
https://www.tm1forum.com/viewtopic.php?t=9971
https://www-01.ibm.com/support/docview. ... wg21973468
nad_i
Post by nad_i »
I've searched through log files and I found out that in previous rights saving there was a block where cell "CubeViews" in the cube }ElementAttributes_}tp_applications has been set. Now I don't have that block.
I don't know how to find out which process has been fired when I save rights. I see that }tp_application_deploy.pro gets a CubeViews as a paramater, maybe this parameter is empty and therefore I get an error. But I don't know how to pass the correct value, it sholud be automatic, but maybe is something corrupted.
