MDX for getting Parent and Children
macsir
Version: PAL 2.0.9
Post by macsir »
Hi, not sure if it is bug or not. In a dimension, when I attache the MDX for getting Parent and its direct children, it works fine.
{ DRILLDOWNMEMBER( {TM1FILTERBYPATTERN( {TM1SUBSETALL( [DimName] )}, "Consolidation1")}, { [DimName].[Consolidation1] } ) }
But if I switch to another parent in the same dimension, it just shows the parent only although it has direct children. It is still in collapsed way.
{ DRILLDOWNMEMBER( {TM1FILTERBYPATTERN( {TM1SUBSETALL( [DimName] )}, "Consolidation2")}, { [DimName].[Consolidation2] } ) }
Not sure why DRILLDOWNMEMBER works differently? I changed to TM1DRILLDOWNMEMBER, it is still the same behavior and same in PA.
macsir
Version: PAL 2.0.9
Re: MDX for getting Parent and Children
Post by macsir »
And I don't see any difference between consolidation1 and consolidation2. That's weird.
jrizk
OLAP Product: Tm1
Post by jrizk »
Doesn't seem to behave differently. Though it might be worth trying:
{ [DimName].[Consol1], [DimName].[Consol1].Children }
{ [DimName].[Consol2], [DimName].[Consol2].Children }
rather than filtering by pattern.
J.Rizk
Tm1 for everyone
macsir
Version: PAL 2.0.9
Post by macsir »
jrizk wrote: Thu Jan 31, 2019 4:55 am Doesn't seem to behave differently. Though it might be worth trying:
Thanks, yes, that's exactly what I did after failure on filtering by pattern. But just want to know why. :?
macsir wrote: Thu Jan 31, 2019 5:45 am
Can you add the dim file, change the element names for privacy, as long as the issue persists.
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
I always use TM1DRILLDOWNMEMBER with the ALL and RECURSIVE arguments. Is there a reason for not using that function vs. DRILLDOWNMEMBER?
Ty
Cleveland, TN
I think I vaguely remember a tech note from an age ago to the effect that DRILLDOWNMEMBER should not be used and the TM1 specific variant should be or perhaps it was the "solution" to a defect that was raised...
macsir
Version: PAL 2.0.9
Post by macsir »
Hi, after testing around, I think I can replicate the issue.
Very simple, as long as the parent exists in multiple rollups and one of grandparent has "&" in between, then it won't show the children of the parent.
See the snapshot,
Dim structure
After MDX
No difference for using TM1DRILLDOWNMEMBER or DRILLDOWNMEMBER.
To me, those two functions have no difference so far based on my experience.
PavoGa
Post by PavoGa »
macsir wrote: Mon Feb 04, 2019 12:50 am Hi, after testing around, I think I can replicate the issue.
The TM1DRILLDOWNMEMBER does not return the desired subset with that syntax regardless of whether there is an ampersand or not in the grandparents' name.
This does return the children however:
TM1DRILLDOWNMEMBER(
    TM1FILTERBYPATTERN(
        TM1SUBSETALL( [test2] ), 'c'), ALL, RECURSIVE)
and this returns the exact same subset of elements:
TM1DRILLDOWNMEMBER( {[test2].[c]}, ALL, RECURSIVE)
Ty
Cleveland, TN
I never understood the use of a TM1FILTERBYPATTERN and then a pattern without wildcards. We can reference the element in a direct way, can't we ?
PavoGa
Post by PavoGa »
Wim Gielis wrote: Mon Feb 04, 2019 3:13 pm I never understood the use of a TM1FILTERBYPATTERN and then a pattern without wildcards. We can reference the element in a direct way, can't we ?
Agree, that does not make a lot of sense to me, either.
I never use TM1FILTERBYPATTERN as a general rule within the context of TM1DRILLDOWNMEMBER, but could see using it to return a set of like elements to drill down upon. Otherwise, it seems a waste.
Ty
Cleveland, TN
macsir
Version: PAL 2.0.9
Post by macsir »
Thanks. OK, my original purpose is to use TM1DRILLDOWNMEMBER to get just one level down from that parent, which is this one (add another child for d). See below,
And the whole structure is like this,
macsir
Version: PAL 2.0.9
Post by macsir »
The TM1FILTERBYPATTERN function here gives me the right result after adding asterisk in it but still not give me right result after combining with TM1DRILLDOWNMEMBER funtion.
Literally, the following two are the same things,
{ [test2].[c] }
But this gives me the right result all the time.
{TM1FILTERBYPATTERN( {TM1SUBSETALL( [test2] )}, "c*")}
Anyway, it is not a big issue and there are a number of ways to avoid it. I am just curious to know why.
macsir
Version: PAL 2.0.9
Post by macsir »
I think I found the root cause of this different behavior. Forget about the ampersand in the parent.
It is just collapsed/expanded status of [c] in the dimension that impacts the different behavior of TM1FILTERBYPATTERN function.
In multiple rollups for [c] in the dimension, TM1FILTERBYPATTERN function just look up for the first appearance of the [c], if that [c] is expanded, then TM1DRILLDOWNMEMBER function can show the expanded status as well. if it is collapsed, then collapsed also.
See the difference below,
0. The whole structure now,
1. After show all, the first [c] in [ba] is collapsed and the second [c] is expanded.
macsir
Version: PAL 2.0.9
Post by macsir »
2. I change the status in the dimension editor to let the first [c] in [ba] is expanded and the second [c] is collapsed for show all button.
PavoGa
Post by PavoGa »
This will get you the one level down including the target:
TM1DRILLDOWNMEMBER( {[test2].[c]}, ALL)
will return c and d only.
Ty
Cleveland, TN
macsir
Version: PAL 2.0.9
Post by macsir »
PavoGa wrote: Tue Feb 05, 2019 1:32 pm This will get you the one level down including the target:
Or, shorter:
DrilldownLevel( {[test2].[c]} )
