Copy Process
Jorge Rachid
Copy Process
Post by Jorge Rachid »
Hi guys,
I have a process to copy data from one cube (calculated version) to another one (historical data), but the problem is when I do this copy using a view from the first cube as source, the value that is copied is diferent. This could be a feeder problem?
I checked all values using check and trace feeders and everything seems to been fed correctly.
Find below screenshot between source and destionation cube:
Now another one showing that values on source cube are fed:
What could be wrong on this case?
Thanks a lot for any help.
JR
qml
Excel Version: 2007 - 2016
Re: Copy Process
Post by qml »
It would be helpful to see your TI code.
A few questions:
- Are the rule-calculated values in the source cube at the N or C level?
- What are the following extract settings for the source view in your TI:
ViewExtractSkipCalcsSet
ViewExtractSkipRuleValuesSet
The reason I'm asking is that it's possible that you could be taking real underlying values from the cube rather than the rule-calculated ones which you are seeing in cube viewer.
Kamil Arendt
Re: Copy Process
Limit your selections in the Source cube (to isolate the issue better) and use AsciiOutput in the Data tab to write contents to a text file.
For 1 year, period, ... that will certainly give you pointers.
Jorge Rachid
Re: Copy Process
I used your tips and I found the error.
The problem is on source view, where I was using two elements instead of one. I changed it and worked.
Thanks a lot.
JR
Re: Copy Process
Well done !
