Left Side Attribute Reference in Feeder?
image2x
OLAP Product: TM1, PAX, PAW, SPSS
Version: 2.0.916.10 on RHEL
Post by image2x »
Hello all,
I'd like to be able to limit a source dimension in a feeder based on an attribute, something like:
FEEDERS;
['FY10', 'Pass1', 'Account' with Attribute 'Type' = 'Mapped' ] => ['FY10', 'Pass1', ... etc];
Is this possible?
TIA. - John
Martin Ryan
Re: Left Side Attribute Reference in Feeder?
Post by Martin Ryan »
image2x wrote: ['FY10', 'Pass1', 'Account' with Attribute 'Type' = 'Mapped' ] => ['FY10', 'Pass1', ... etc];
Not like that, but something like
['FY10', 'Pass 1'] =>
DB(if(attrs('Dim', !Dim, 'Attr')@='Mapped', 'CubeName', ''), !Dim1, !Dim2, !Dim3);
I.e. in the right side of the feeder, do the test, and then if true insert the cube name, if false, then '', which means the feeder won't go anywhere. You have to use the fully quantified DB('...'); ref because the if statement makes it too complex to do the simple [''] ref.
Note, with conditional feeders, if the condition is met (or not met) at load time, then subsequently changes to not met (or met), then the feeder won't update until next time the server is bounced or the rule is saved.
Martin
Jodi Ryan Family Lawyer
image2x
Post by image2x »
Thanks Martin.
So with conditional feeders, if the cube I'm feeding is itself, I still would need to use the DB('Cube') function?
That's right image2x as soon as you move away from a simple square bracket reference you need to use a DB () reference even if you are feeding internally. Cheers
Eric
Version: 9.4
Post by Eric »
There is one small thing you can do on the "left side".
Common - Write 3 Line
[…, ‘elem1’, …] => …;
[…, ‘elem2’, …] => …;
[…, ‘elem3’, …] => …;
Possible - Write 1 line
[…, {‘elem1’, ’elem2’, ’elem3’}, …] => …;
I am not sure I would recommend it, but it is something to be aware of.
Eric
Post by David Usherwood »
Couple of things:
a On 9.0 (at least) you can't use the {} notation on the LHS of a feeder;
b For refiring conditional feeders, you can use the TI command CubeProcessFeeders.
image2x
Post by image2x »
Thanks guys. I appreciate the help.
TM1 is incredible... the power of real time data is amazing.
Yes, it's a shame their "improvements" are forcing us to move further away from a real time appraoch... I guess it depends if you are new to TM1 or have had a longer experience.
image2x
Post by image2x »
Steve Rowe wrote:Yes, it's a shame their "improvements" are forcing us to move further away from a real time appraoch... I guess it depends if you are new to TM1 or have had a longer experience.
Steve, can you elaborate? Is this in reference to what's being planned for the merging of Cognos Planning and TM1? Thx.
Hi image2x
See this thread.
If you are new to Tm1 and have gone straight in at 9.4, you probably won't notice the distinction. The object-locking model between version 9.0 and 9.1/9.4 dropped from the server level to the cube level, this happened before Cognos (AFAICR). Anyway I won't sidetrack this thread further here, as I've set up a poll to see what other peoples view is.
