Problem with TM1 uninstall wizard
bshaver
- OLAP Product: TM1 + WebWorq
- Version: 10.2.2 FP4
- Excel Version: 2010+2013 [32+64bit]
I'm trying to uninstall TM1 v10.2.2 on a test server, but when I run the uninstall wizard the packages list is blank. How do I get past this? Thanks.
- uninstall wizard.jpg (61.18 KiB) Viewed 4299 times
hittony
- Version: 10.2.2 FP6
Re: Problem with TM1 uninstall wizard
Hi, you can always have a try with an independant uninstall tool.
!TM1Rules
- OLAP Product: TM1\Cognos Express
- Version: All
- Excel Version: 2013 + 2016
Alternatively, you could just try and re-install 10.2.2 over the existing install and then re-try the un-install. Make sure you also 'run as administrator' for installs\un-installs.
